Old 09-10-2023, 02:12 PM   #8793
Lantanafrs2
Drives: 2013 frs red
Cv?
Lantanafrs2 is offline   Reply With Quote
Old 09-10-2023, 02:20 PM   #8794
spike021
spike021's Avatar
Just spent a few mins driving more.
It does happen in neutral and when stopped when I rev to about 2500-3000rpm. In lower gears it happens more between 2000-3000.
Above 3k I don't notice it.
Usually I shift around that range... could it be transmission related?
Car sounds fine if just idling and it's pulling and stuff fine while accelerating.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 09-10-2023, 08:29 PM   #8795
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Suddenly this afternoon I became a sewing machine restorer. My wife couldn't not get this from an elderly lady who put this out front for free. It didn't spin.
5 minutes with 5 in 1 oil and got it going.
1942.
My wife is super exited. Hope I can time it.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
bcj (09-11-2023), blsfrs (09-11-2023), spike021 (09-10-2023)
Old 09-10-2023, 08:53 PM   #8796
Should clean out all the old oil before the varnish sets up again. Might as well if you're already re-timing it.
Old 09-10-2023, 09:02 PM   #8797
Sapphireho
Famous Potatoes
Sapphireho's Avatar
There is no old oil. Just joints that need regular oil in the main shaft. Many joints were seized. Sprayed with brake cleaner and oil, then oil 10 more times spinning. Motor runs well. Going to put it back in tomorrow.
I have no idea how to re-time it.
Right now I have the motor out and soaking the rubber wheel that turns the main shaft.
Interesting machine.
blsfrs (09-11-2023), soundman98 (09-10-2023), Ultramaroon (09-10-2023)
Old 09-10-2023, 09:15 PM   #8798
Yeah. Many people used 3-in-1 oil to lube them. It becomes like glue when it varnishes. Real sewing machine oil is pure mineral oil. No plant-based stuff. wd40 thins the 3-in-1 varnish but eventually evaporates. edit... I missed the part where you said you cleaned and lubed a bunch of times. It sounds like you cleaned it all out.
Sapphireho (09-11-2023), soundman98 (09-10-2023)
Old 09-10-2023, 10:06 PM   #8799
soundman98
ProCrastinationConsultant
soundman98's Avatar
There's been a couple machines like that at goodwill lately. But all the rubber is either missing or so cracked and dry rotted and about to go missing.
I've still got a snow blower I need to fix up. Needs new fuel lines and a carb, then it's a housewarming gift to a friend.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
Sapphireho (09-11-2023), Ultramaroon (09-10-2023)
Old 09-10-2023, 10:15 PM   #8800
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Actually, I used this.
soundman98 (09-11-2023)
Old 09-10-2023, 11:31 PM   #8801
I guess if you're ok with the off-brand stuff...
Old 09-11-2023, 05:46 AM   #8802
Kaotic Lazagna
Drives: GR Corolla
A heat shield some how came loose perhaps?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
spike021 (09-11-2023)
Old 09-11-2023, 06:42 AM   #8803
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
It almost sounds like a defective pulley. Could be a pump too.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Old 09-11-2023, 10:11 AM   #8804
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Singer vintage sewing machine oil is off-brand?
My wife now has 3 sewing machines. She also got my mom's Singer 401.
Ultramaroon (09-11-2023)
Old 09-11-2023, 11:48 AM   #8805
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The cattle panel worked great. We did tomatoes on it. I'm going to get a couple more next season for beans and peas.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
blsfrs (09-11-2023), Dadhawk (09-11-2023), Spuds (09-11-2023), Ultramaroon (09-11-2023)
Old 09-11-2023, 12:03 PM   #8806
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I ended up with a 900lb motorcycle in my shop for repair. Been sitting for like 8-9 years. Transmission howl. Hopefully just a clutch but I heard 4 gear is weak in these.
blsfrs (09-11-2023)
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
