Old 09-06-2023, 10:24 AM   #1
Compelica
Compelica's Avatar
Drives: 86 GT
Trouble with driver side window after repair
I recently got myself a brand new door after a minor accident. The door and glass were replaced with brand new ones, with the other components transferred over.
However, the window had a few issues. It would jig a little before going up and down, and would make a very loud clack when lowered or raised at midpoint. Also the window would screech as it fully lowers into the door.
Clacking sound:
Screeching sound (WARNING: LOUD):
I'd be sending it back to the service center (official Toyota) under repair warranty but I wanted to understand the problem that I'm facing in the first place? Should I still be using my window at this point?
@Ultramaroon or anyone else? Thanks!
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 09-06-2023, 10:58 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
It might just be loose motor, track, or regulator bolts.
The door panel is pretty easy to pop off to take a look.
The screeching woke up my dog though.
Old 09-06-2023, 11:49 AM   #3
The pads are going to scratch the glass. The whole mechanism needs to be aligned properly.
Old 09-06-2023, 01:06 PM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
:o
I take that I should not be winding down the window for now? What was odd was the clacking was there since I got back the car, however the screeching was only recent as the clacking video did not have that sound.
Old 09-06-2023, 01:17 PM   #5
Originally Posted by Compelica View Post
I take that I should not be winding down the window for now? The clacking was there since I got back the car, however the screeching was only recent, the clacking video did not have that sound.
If the tracks are forcing the window against the outer seal around the perimeter, it will open and close easily with the door open.
There are also adjustable stabilizers on the inside at the top front and rear of the door frame. If they are too tight, they will scratch the window. Can feel for them by operating the mechanism with the door open.
Old 09-06-2023, 07:53 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
take it back to whoever performed the repair. it's not done correctly yet.
Old 09-08-2023, 02:00 AM   #7
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks for the feedback. Just sent it back today - no more clacking sound and screeching but will leave it for a few days to test. However the window still has that initial side-to-side movement when moving up/down from stationary, captured below:
Passenger side - OK
https://youtube.com/shorts/yghy0mrdxsw
Driver side - not OK
https://youtube.com/shorts/X5_TY2yYoQs
Will look up later, but why does the side to side movement happen?
Driver side window seal TSB PR138 Issues | Warranty | Recalls / TSB 2 02-11-2022 08:20 PM
Driver’s Side Window Weatherstrip gm5oh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 12-03-2021 01:20 PM
Driver side window OEM Lorico Canada Classifieds 2 01-05-2016 07:30 PM
Driver Side Window Streak kevinchavarria Cosmetic Modification (Interior/Exterior/Lighting) 14 09-16-2015 11:42 AM
Driver side Window button Quvit92 Scion FR-S / Toyota 86 GT86 General Forum 16 01-09-2015 06:55 PM
