| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#15 |
Drives: 2013 frs base
As @Ultramaroon pointed out, I had a significant oil pressure drop with the JR dual rad. JR refused to acknowledge any issue. I kept the rad but installed a Setrab 34 row cooler. It had the least drop without over cooling but I haven't tested it on track yet. Pressure-wise it solved what the JR dual rad created.
It looks like you are running the Accusump as a "dampener". This was the original recommendation from Element Tuning when I had my engine built. https://www.ft86club.com/forums/showthread.php?t=153186 |
#16 |
Drives: BRZ 2023
What temperatures were you seeing before adding oil cooler? 30 psi drop is crazy, would pressure gain from viscosity gain from oil temperature drop due to OC would even cover that?
#17 | |
Interesting results. First Gen car here, I had a JR Oil Cooler that was seeing a larger pressure drop across the core.
I initially suffered a failure due to a rocker arm. Flushed the cooler but reused it (hindsight should have replaced it in its entirety). Saw about a 25-35 PSI Delta after I rebuilt the engine. Consulted with JR - they told me, within email that nominal drop is 5-10 PSI drop Quote:
Kyle H. - #89 STX
#18 | |
FT86Club Official Vendor
Drives: 2023 BRZ
With the stock configuration, we would hit 130*C by the second lap but it would stabilize there. You can't use a thicker viscosity to compensate for the higher pressure losses of the JR dual oil cooler. The best compromise would be to choose an air to oil cooler with less pressure drop. That's something we're developing.
#19 | |
Drives: BRZ 2023
#20 |
Drives: 2023 Gray BRZ
Accusump as dampener? So the 2-qt reservoir is essentially empty when the engine is off.... loads up at start with oil pressure building, and dumps when pressure goes below its threshold? Am I getting this right? This would mean you need 2 extra quarts in the sump with the engine off... and something of a drain at the critical startup phase.
#21 | |
Here's my set up. https://www.ft86club.com/forums/showthread.php?t=152642 |
#22 |
Drives: '23 BRZ
Oil cooler is addressing a problem that doesn't exist, if causing massive 30psi pressure drops surely it's blocked somewhere? Anyway, I'd just lose it and run good 30- or 40-weight. 130C/266F track oil temps are not a big deal with appropriate oil...
Thanks for the vid! Thinking about Accusump.... Last edited by ZDan; 09-06-2023 at 09:59 AM. |
#23 | ||
Drives: 2023 BRZ
A 2qt accusump doesn't actually hold 2qts of oil. 2qt refers to the overall volume, but part of it is the pair cushion. It holds closer to 1.5qts. If you're not at the track, we would recommend storing the excess oil in the Accusump and shutting the valve. In this configuration, your engine's oiling system behaves no different from stock. Quote:
While I do agree that 130C oil temps are tolerable with a high quality oil, it was just higher than we'd like to see. There's no magic threshold on what's acceptable or not. On the testing day, we were running 40minutes out of each hour. We want to be able to run our car non stop without cooling laps without concern.
#24 | |
Drives: '23 BRZ
I've never thought an oil cooler was necessary, and the more I've looked into it the more I think the negatives outweigh the "positives" which are debatable... More cost, more weight, more potential failure points (leaks are common), and in some cases -30psi oil pressure? Damn... You may know more than I but I've heard that the reported oil [edit]temperature to the canbus is a calculated, estimated "max", and 275F reported correlates to 255F sump temp which I think is what people have historically gone by for oil temps. I know that's the case with C6 Corvette, reported oil temp is calculated, and it doesn't go into "limp" mode until calculated/reported 160C (320F) oil temp! I think there's a reason the FT86 goes all the way up to 340F, with 270F being at like 2/3 the range. Last edited by ZDan; 09-06-2023 at 05:04 PM. |
#25 | |
Drives: BRZ 2023
#26 | |
Drives: 2023 BRZ
The 30psi loss that we saw was specific to the radiator oil cooler combo, air to oil coolers should not be so restrictive. I'm not sure what you're referring to about the oil temp and pressure on the canbus. Our cars stock do not have an oil pressure sensor. There's no reported oil pressure. One thing to keep in mind is that, the oil temperature you measure is not the temperature the oil is at when it's at the bearings. The oil gets hotter than what you measure. What temperature? hard to say. Back to the first point, in our eyes, the best option is to have lower oil temperatures and not cause extra resistance in the oiling system.
#27 | |
Drives: BRZ 2023
#28 | |||||
Drives: '23 BRZ
| 2022+ BRZ/GR86 Intake Snorkel - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 6 | 08-06-2023 09:08 PM |
| 2022+ BRZ/GR86 CANbus Adapter - Ansix Auto | Ansix Auto | Audio/Visual, Electronics, Infotainment, NAV | 11 | 07-04-2023 04:01 PM |
| GR86/BRZ FA24 Oil Pressure Loss Demonstration | Stevedave | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 2 | 06-28-2023 09:07 AM |
| 2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 1 | 11-28-2022 05:02 PM |
| 2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
