| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
FT86Club Official Vendor
Drives: 2023 BRZ
Ansix Auto FA24 BRZ/GR86 Accusump Oil Pressure Drop Testing Results
We've uploaded a video showing our results from testing a 2qt Accusump on our 2023 Subaru BRZ Track car.
Please feel free to comment on YouTube or post here if you have any questions.
#2 |
Drives: Mini Cooper S
You mention seeing a drop due to the JR dual radiator being paired with the OEM exchanger. But I'm not sure you specified what the drop looked like. Was it just a lower overall pressure? Or were the dips worse (longer and lower)?
#3 |
Drives: 2023 BRZ
The pressure drops were from the cornering. The lower overall pressure was due to the JR radiator and oil cooler combo. The instructions suggest to install it along with the stock heat exchanger. We removed the stock heat exchanger to offset the additional resistance caused by the JR cooler.
As mentioned in the video, the JR cooler makes your oil pressure around 30psi lower vs without. Removing the stock HX recovers about 10psi.
#4 |
Thanks very much for so effectively testing and reporting your results. @blsfrs, did you see this? Starvation issues aside, it looks like your experience with the JR radiator is not unique. I'm more disappointed than surprised. Caveat emptor.
#5 | |
#6 |
Does that mean pulling the stock HX is worth 10 psi on a stock setup? If so, I'm going to pull it and add a dedicated OC. I know from the 1st gen that the Setrab 613 core is only about a 5 psi restriction (by itself, no lines). Sounds like a dedicated OC would be a better solution (less or comparable restriction, much more cooling).
2022 BRZ Build 2013 FR-S Build |
#7 |
Drives: 2023 BRZ
Yes it does, but the 10psi is done at 95*C oil temp. The difference will be smaller at higher oil temps / lower oil viscosities. You're right about the dedicated cooler, that's what we mention in our recommendations in the video.
BioRebel, check out this post about the JR radiator / cooler combo. https://www.ft86club.com/forums/show...&postcount=346
#8 |
Drives: Toyota 86 (old) / GR86 - (current)
Can you take off the heat exchanger carefully so it can be replaced and look like it hasn't been touched if failure happens?
#9 |
Drives: 2023 BRZ
Absolutely you can.
#10 |
Drives: 2022' GR86 Premium 6MT
So pretty much, to mitigate the oiling issues on track you need to money dump another what, $5 - $8k in parts im assuming?
Unfortunate.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#11 |
Drives: 2023 BRZ
Where did that price come from?
Just use a good oil and the accusump with install kit is $600. You can skip the baffle. It’s up to you if you want an oil cooler.
#12 | |
#13 |
Drives: 2023 BRZ
Thats the data we collected. We have no reason to make it up. I’ve posted the deltas on the other forum. Feel free to disregard it.
We’re not the only ones that have documented this. https://www.*********/threads/vincen...23/post-150985
#14 |
Drives: 2023 Gray BRZ
Any theories as to what is causing the pressure drop? The pickup is starved of oil, the pump loses prime, etc? If so, where is the oil during the right turn?
PS: Nice video and thanks for doing the work. |
| 2022+ BRZ/GR86 Intake Snorkel - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 6 | 08-06-2023 09:08 PM |
| 2022+ BRZ/GR86 CANbus Adapter - Ansix Auto | Ansix Auto | Audio/Visual, Electronics, Infotainment, NAV | 11 | 07-04-2023 04:01 PM |
| GR86/BRZ FA24 Oil Pressure Loss Demonstration | Stevedave | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 2 | 06-28-2023 09:07 AM |
| 2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 1 | 11-28-2022 05:02 PM |
| 2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto | Ansix Auto | Engine, Exhaust, Bolt-Ons | 0 | 11-18-2022 05:15 PM |
