Old 01-29-2023, 09:16 AM   #4299
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
I know this is a longshot. but does anybody have this part that they want to get rid of. Spare or otherwise? Was doing some maint. and saw that when my bolt snapped it turned the mounting plate into some trash.
2015 Hot Lava FR-S IAG 800 FBM Turbo Kit
KxngCorey is offline   Reply With Quote
Old 05-22-2023, 01:07 PM   #4300
pkat696
Drives: 2013 Scion FR-S 10 Series
California referee smog check?
Anyone in California pass a referee smog check with this kit? If so, any tips and tricks?
pkat696 is offline   Reply With Quote
Old 08-11-2023, 08:47 PM   #4301
GraysBRZ
Drives: Silver 2017 brz limited
Tunes for kraftwerks c-38 kit for 2017 BRZ
Looking for information on where I could get a tune for the kit. I want to purchase the kit and do the install however I have not been able to find anything related to a base map for it.
GraysBRZ is offline   Reply With Quote
Old 08-11-2023, 09:32 PM   #4302
KxngCorey
KxngCorey's Avatar
I'm 10,000 miles in tuned with xero limit
Sent from my SM-S908U using Tapatalk
Old 08-24-2023, 08:12 PM   #4303
GraysBRZ
How would i go about getting a base tune form them?
Old 12-07-2023, 01:27 PM   #4304
Apolllo
Drives: 2018 Subaru BRZ Limited
Does anyone know what the difference is between the 13-16 kit and the 17-20 kit? Would you be able to get a 13-16 kit fit a 2018?
I asked this same question to Kraftwerks, and they just came back with "Intercooler piping is different" which I figured, but didnt answer my question on if it would fit. I dont mind cutting or making a few modifications to get the piping to fit...I just dont want to have the intercooler pipes sticking out the side of the bumper or something lol
Apolllo is offline   Reply With Quote
Old 01-07-2024, 02:48 PM   #4305
jflogerzi
jflogerzi's Avatar
the front bumpers are different and thus a slight modification will be needed in my guess with piping
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 01-08-2024, 06:54 PM   #4306
Apolllo
Seemed like it fit up pretty well. The intercooler piping on the driver side was snug, and hitting some metal frame, but I just put some pieces of rubber between them. Other than that seemed fine.
Unfortunately, the Rotrex unit was be bad and seized up. The metal fins busted and made their way through the intake tubes, intercooler, and tiny pieces somehow made it to the throttle body which threw multiple codes in my car. Got burned buying used trying to save a few bucks
Old 04-18-2024, 06:23 PM   #4307
srhode579
Drives: 2013 Ablaze FRS 30K miles.
C38-91 Kraftwerks Racekit Help
Hello! I have been working with a c38-91 kit and am running into an over boosting problem. I have the 95mm pulley attached to the blower and 128mm on the crank.
This kit is making way too boost for my stock frs. I am using the MAP sensor which saying at 7.2k the MAP is reading about 2 bar (~14psi). I obviously ran into fueling issues as the car is stock. To lower the boost I tried the 100mm pulley option from the s2k kit. Unfortunately this pulley is 12mm thicker and contacts the ac compressor.
Has anyone run into this over boosting problem and come to a solution? I don’t want to change my fueling as this is a daily and I’m not trying to break any records.
If I can’t find a solution I will be selling this brand new kit along with some other goodies that came with it (fuel pump, larger injectors, 72mm throttle body).
Cheers
srhode579 is offline   Reply With Quote
Old 07-24-2024, 08:43 PM   #4308
FTemplar
Drives: BRZ Sport-tech 2013
Hello,
New Kraftwerks C30 owner here
2013 Subaru BRZ AT Transmission
243 WHP @ 9 PSI
187 LB Torque
I went for a conservative setup so that I may enjoy this car for years to come.
This is my build thread (Retro BRZ) :
https://www.ft86club.com/forums/showthread.php?t=91678
FTemplar is offline   Reply With Quote
Old 08-21-2024, 03:12 PM   #4309
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
Anyone thought of swapping out the intercooler for a different kind or brand?
My front bumper support bar's holes have been rounding out from the hooks of the KW intercooler and has been causing some noise (it's been gosh, 60k or so with all sorts of life on the roads and tracks). Kinda looking to see if anyone has used a different one that positions similarly but mounts with a different method.
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Mykii is offline   Reply With Quote
Old 11-09-2024, 12:55 PM   #4310
AEBRacing
AEBRacing's Avatar
Drives: Toyota FT86
Fuel Injector needed for small KW C30 pullley (diam 90mm)
Hi guys!!! for those people that have experience in this KW kit w/Rotrex C30-94 and small pulley (diam 90mm 13/14 psi)
Finally, I flashed the ECU with local Ecutek Tunner Certifícated here in Argentina, I have the KW kit with SC Rotrex C30-94 small pulley (diam 90mm and >13 psi) and others mod like Skunk2 El header, Tomei OP, and 2,5" exhaust pipe w/o CAT
Unafortunatly the tunner said the map was restricted caused by OEM fuel injectors capacity, the RPM were limited to max 7k due to the fuel injectors capacity, after that the % of injectors charge required more than 95% and the AFR started to increase dramatically
Did you have similar experiance with this configuration in terms of OEM restriction fuel injectors? I undestand the FA 20 engine require and special rich AFR close to 11,4 with Forced Induction kits and this requirement force to change the OEM fuel injectors for others with more capacity
Please could you share your experiance and recommend brand and type of aftermarket fuel injectors kit to use for tis type of KW kit configuration?
Thanks for your help!!!
AEBRacing is offline   Reply With Quote
Old 04-07-2025, 01:12 PM   #4311
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
I am running DW 750 CC injectors and with the same small pulley setup. I had one of included O-rings leak and sprayed fuel everywhere. If you go with DW injectors, it wouldnt hurt to swap out the o-rings right away as a precaution?
projek_01 is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
