Old 08-23-2023, 08:56 PM   #1
Migel_Iman
Drives: 2013 Scion FRS Red
**help**86 TRD lowering spring causing issue
Hi, I'm new to here and wanted some advise if anybody experienced this.
I have a 2013 manual Scion FRS / 86.
About 2years ago I installed TRD lowering coil kit (springs) on my stock KYB shock,strut kit. The KYB shock/strut kit was brand new also at the time just two years ago but now my cars tire makes screeching noise when I turn at a corner at very low speed like 5kmph, just slowly turning at a traffic light but tire sounds like I'm going at 100kmph drifting. I installed new sway bar links and tire still has tread. I brought it to my mechanic and he said my upper strut mount is worn due to the TRD spring that I installed and its causing higher spring rate so the KYB regular strut mount got worn so therefore its effecting the tire noise. Is that true? and what solution I would have? My mechanic said I should install aftermarket strut mount so it can withstand the TRD spring rate but when I called around for aftermarket strut mounts, they said most of them will only fit aftermarket coil kits like TEIN,etc and not on a regular KYB. I was thinking of getting a TRD strut mount but I heard it only fits JDM 86??? Mine is N.America. Has anybody installed TRD lowering springs and had there other suspension parts damaged due to it? Any advise would be great please!
Migel_Iman is offline   Reply With Quote
Old 08-23-2023, 09:05 PM   #2
AsphaltJ
Drives: FR-S '15 Asphalt/Legacy GT '05 Blck
No need to for after market strut mount. Change to OEM or replacement parts.
Maybe you can confirm the diagnostic with this video:
AsphaltJ is offline   Reply With Quote
Old 08-24-2023, 03:04 AM   #3
LancePower
Drives: 2020 BRZ tS
I had TRD Lowering Springs on a FRS and they blew out the stock rear dampers every 5K miles.
Luckily it was still under warranty the whole time.
LancePower is offline   Reply With Quote
Old 08-25-2023, 11:06 AM   #4
Tokay444
They pair much better with the Sachs dampers.
OP, did you get an alignment after the install?
Old 08-25-2023, 12:52 PM   #5
Dake
Dake's Avatar
The strut mounts were known weaknesses of the OEM suspension, so if they've never been replaced, they'd likely be bad by now even with everything else stock.
I did the TRD springs, which quickly blew out the OEM struts. I swapped to Bilstein's with new mounts and haven't had any problems since (it's been probably five years now).
Dake is offline   Reply With Quote
Old 08-29-2023, 01:35 PM   #6
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I remember when I did my suspension (Bilstein struts, Whiteline sway bars) I had considered getting more robust top hats. I can't remember if they came from the PP stock setup or maybe from the WRXs (?) but they weren't cheap. Recently my suspension does a lot of clunking (thanks to these wonderful CA roads). I new alignment may be in order.
MJones_RB is offline   Reply With Quote
Old 09-10-2023, 12:17 PM   #7
norcalpb
norcalpb's Avatar
Yea the JDM TRD top hats will fit your car.
Like mentioned, while you are in there I would look into upgrading those KYB to used Sachs from a forum member (cheapest) or new Bilstein b6 or b8 (relatively expensive).
Old 10-08-2023, 07:08 PM   #8
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I ran TRD Pro Kit springs on used Koni Yellows using Pedders offset (-.75) top mounts for about 20,000 kl. This combo performed admirably without any noises. Koni’s being adjustable gave me sweet street and track flexibility.
Have now moved up to Ohlins R&T with adjustable camber plates which do forward vibration/noise to the cabin, but tolerable.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
lowering spring install rtalich Northwest 11 01-28-2018 02:00 PM
Lowering Spring Install Help! Richard_BRZ CANADA 2 11-26-2017 08:50 AM
Help with lowering spring install in PDX? AnotherDude000 Northwest 4 09-05-2017 01:22 AM
LOWERING WITH SPRING IN CANADA bhbnuckle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 03-14-2014 12:42 AM
WTB Lowering Spring FRS_Jack Want-To-Buy Requests 0 02-27-2014 12:48 AM
