Old 08-09-2023, 04:44 PM   #1
ChaseTheFox
Drives: '90 LX 5.0L, '01 F-350 7.3L
Which first, brakes or coilovers?
So I've got the car up in the air and I've got all the parts I need to do coilovers, rotors, pads and SS lines.
Any recommendations on which order I should do these in?
I'm kind of thinking remove rotors to get them out of the way so I have more space to work on the coilovers, and say brakes for last. Sound about right?
Seriously addicted to Muscle and Momentum Cars:
Since editing garage is unavailalble:
2017 BRZ WRB LTD PP 6MT E85 OFT Stg 2+ CNT Header FA 500s R1 Concepts Brakes
2001 F-350 7.3L
1990 Mustang LX 5.0L
ChaseTheFox is offline   Reply With Quote
Old 08-09-2023, 04:48 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Sounds about right.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 08-10-2023, 12:37 PM   #3
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'd do the coilovers first and just leave the brakes as is until you're done. When installing coilovers/struts, many times you're maneuvering the hub/rotor assembly around to line it up with the bottom on the strut/coilover. That includes getting the rotor dirty, scratching it, etc.
The problem with removing the rotor is you have to remove the caliper, so then you have that dangling around on it's own... if you don't reattach it, which is an extra step. I usually use a hanger and hang it from the spring above, which wouldn't be there when removing the strut.
Coilovers first. Then brakes. Just me.
cmiovino is offline   Reply With Quote
Old 08-10-2023, 03:28 PM   #4
ChaseTheFox
Thanks guys good advice, and thanks for the hanger trick. Spent the whole night dealing with removal of front endlinks since those are going too, damn you rust!
Sent from my SM-G975U1 using Tapatalk
2001 F-350 7.3L
KW V3 coilovers, Brakes, Endlinks, etc gc3 Brakes, Suspension, Chassis 7 12-10-2021 02:45 PM
wanted: coilovers, big brakes & carbon hood Turbo Canada Classifieds 0 05-16-2018 10:01 PM
BACK TO STOCK SALE (WHEELS, COILOVERS, TRDBODYKIT, LIGHTS,BRAKES,MORE ) SpecPer Audio/Visual, Electronics, Infotainment, NAV 8 07-02-2015 09:54 PM
Coilovers and brakes? d1ck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-05-2013 11:23 AM
KW Coilovers, Brembo Brakes, Cusco and more! at Vivid Racing vividracing Brakes, Suspension, Chassis 5 10-15-2012 06:23 PM
