Old 07-18-2023, 01:16 PM   #309
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Originally Posted by Desertnate View Post
I've been running 32psi on 660's (225/45/17's) in DS. You're comment about running a hight PSI has me thinking. I might give it a try next event. I assume you're running the same pressure on all four corners?
I usually run 2-3 PSI lower in the rear.
With the 660's, I did 32/30 initially and ran the large part of last year thinking that was ideal. With any new tire, I do the standard chalk or look at wear in the fronts, get it to the triangles, then adjust the rear to suit it.
Had a few people think I was nuts running them that low when I mentioned it. Tried 37/35. Instantly had more grip and everything just felt better. Times slightly improved, but definitely did.
Same tire size, wheel size, class, etc.
I've since switched to A052's again as I didn't like the way the 660's heat cycled over the year, but I'd definitely recommend higher at about 37/35 with those. It made a noticeable difference for me.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
Desertnate (07-18-2023)
Old 08-08-2023, 08:45 AM   #310
foshjowler
Drives: 2022 BRZ; 2014 BRZ
We went to a new site this past weekend right in Raleigh, 15 minute drive from me, and where the Hurricanes and NC State teams play. Brought in almost 150 people to the event when normally 100 is a good turnout. Took home top Pax, and 2nd raw to an AMod FSAE car brought by the NC State motorsports club.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
foshjowler is offline   Reply With Quote
The Following User Says Thank You to foshjowler For This Useful Post:
RT-BRZ (08-08-2023)
Old 09-18-2023, 01:40 PM   #311
foshjowler
First event in the STX car. It did well, didn't do anything weird and think I was 3rd of 90ish. A well driven kart and Camaro are hard to compete with on a power favored course.
This site is unlike any others with the banking and speeds, so I'm still unsure of the balance. It was understeery on the banking and a little tail happy on the flatter parts, but I was in 3rd the entire time, so can't really come away with any real thoughts until I drive a more normal site. But the car didn't break, so a good shakedown in my books
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 09-18-2023, 02:24 PM   #312
cueball89
Drives: 15 Impreza
2nd time out with my 23. 1st time with my stx setup from my 2016, coilovers, wheels/tires and front swaybar.
Looking at the video now I think I should have stayed wider on the last left hander to get back on the gas quicker. The extra power from the fa24 is a welcome change.
cueball89 is offline   Reply With Quote
Old 10-22-2023, 07:13 PM   #313
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Old 11-06-2023, 01:58 PM   #314
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Old 11-14-2023, 11:08 AM   #315
dragoontwo
dragoontwo's Avatar
Final event this year.
Old 02-12-2024, 04:04 PM   #316
Espi
Espi's Avatar
Drives: 17 BRZ
The slower part of the right course I found time by downshifting after my camera died. Any other tips and pointers welcome. This was my first AutoX in 20 years lol
Espi is offline   Reply With Quote
Old 02-27-2024, 08:17 AM   #317
foshjowler
First event of the year, first time at ZMax in this car, and with the much softer spring rates and softer rear bar. I turned stabilization on in the camera at some point in the off season, so the video kinda sucks.
The run was solid, felt I could have cleaned things up here and there, but overall it was a good run. Still have some adjustments to make before I'm totally happy with the car. Ended up 5th PAX out of 203, and about 4 tenths behind Mudge. Hopefully that difference continues to fall as I get more comfortable in the car and settle on a setup.
https://photos.google.com/photo/AF1Q...xj0Jag7HtbXzrb
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 03-04-2024, 06:15 PM   #318
cmiovino
cmiovino's Avatar
It's been about 4.5 months, but we're back at it here in PA. Just a test and tune. Our real events have another month to kick back in.
Old 03-23-2024, 05:26 PM   #319
dragoontwo
dragoontwo's Avatar
Fastest time of the day because the faster people didn't show up.
I beat an S2000 by .5 second and an NSX was 3rd.
I'm still struggling to get an angle that I like for the video. Suggestions on GoPro mount points?
Old 03-24-2024, 12:08 PM   #320
jcaserta
Drives: 2015 FR-S
Just suction cup it to the driver's side rear window near the bottom, at a right angle. You should be able to get it so it can see the driver, the front left wheel, and the course in front of the car.
still too cold here and we're not autocrossing yet but here's one of my videos from last year to see what it looks like
jcaserta is offline   Reply With Quote
The Following User Says Thank You to jcaserta For This Useful Post:
strat61caster (03-26-2024)
Old 03-25-2024, 11:10 AM   #321
foshjowler
Made the 8 hour trek to Moultrie, GA for the SCCA Solo National Tour. Day 1 I would define as steady. Not a bad run, but left a fair bit of time on the table, and thus dug a 6 tenths hole on day one. Day 2, was a pretty good run, and just about made up all but 0.042 the 6 tenths. Went way wide at the beginning, but other than that it felt really good. Still brought home a trophy, and ended up 13th in PAX, so not a bad result for my efforts.
2022 BRZ (sold)
2014 BRZ
2014 Cayman
Autox Videos
Old 03-26-2024, 06:48 PM   #322
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Either behind driver side door as mentioned above and used in many videos posted here or get a headrest mount and put it in the center just behind the driver. Location needs to be consistent when comparing runs - no helmet cam unless it’s for the ‘gram. You need to see where your head is pointed to identify any issues with your vision which takes out most exterior views and the right side. And you need to see your hands on the steering wheel to identify any issues there. Mounting on the rear window doesn’t give enough view of the track/course imho so there’s really only two options in my book for your primary camera.
Views looking from behind the sunroof so you can see the course as well as the driver are the best, but not an option here. Here’s my latest run that doesn’t totally suck with the center view. Amazon GoPro head rest mount and something decent will come up for $40.
ineedyourdiddly
Track Videos - Directory and Discussion Dave-ROR Tracking / Autocross / HPDE / Drifting 709 09-22-2025 08:12 PM
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* 86SPEED Groupbuys 74 11-09-2016 01:45 PM
Feldys Autocross videos feldy Tracking / Autocross / HPDE / Drifting 25 06-13-2013 02:58 PM
Need help with some tips for autocross Toyota GT 86 Tracking / Autocross / HPDE / Drifting 10 04-30-2013 06:43 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
