Old 08-05-2023, 11:56 AM   #15
Evolbrz
Drives: 2017 BRZ 3.0L swap
Long time no update had time to get back to the project and I got a lot done... Im at a point were I can try to start the car as I hard wired the fuel pump to a relay on a switch and bypassing the stock relay.
But the problem is I can get the car to start I have a feeling my connection even tho I hear the fuel pump dont think fuel is making its way to the two lines to my engine.
Can anybody with experience with the oem fuel pump chime in to help me... I got the green wire for positive and grey wire to ground from the fuel pump.. what am I missing I know the fuel system on these cars are special but isnt it just 1 fuel pump and regulator? really want to get her started and start tuning
**EDIT** fuel is making its way into rails ... currently troubleshooting with ECU master support
Evolbrz is offline   Reply With Quote
The Following 3 Users Say Thank You to Evolbrz For This Useful Post:
alphasaur (08-07-2023), Drifter X (08-06-2023), Irace86.2.0 (08-05-2023)
Old 08-05-2023, 08:13 PM   #16
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Reference:
https://manuals.plus/deatschwerks/9-...ule-manual.pdf
https://cdn.shopify.com/s/files/1/08...heet.pdf?35048
Green is positive. Grey is ground like you said. Red and violet are for the fuel level gauge.
Relay should have a power wire from the battery to receive power, something that is a switchable power to turn the relay on and off to close the circuit, a wire powering the fuel pump going to the OEM green wire, and a ground wire.
Sounds like you have fuel. You should hear the fuel pump when the key is in the on position and not just when the car is started. What are you using for a trigger wire?
Does the engine sound dry or does it sound wet like is it just turning over and could be missing spark or fuel, or is it getting some fuel with ignition and burbling trying to start, but maybe some timing, injector duration or fuel pressure is off?
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 08-06-2023, 04:24 PM   #17
Evolbrz
trigger is on key switch
. pump working fine. spent some time today troubleshooting and seems like my DBW is not opening on cranking.. I know it is operational maybe just a setting.. should here back from ecumaster soon they have been very helpfull.
The Following User Says Thank You to Evolbrz For This Useful Post:
Irace86.2.0 (08-06-2023)
Old 08-06-2023, 08:48 PM   #18
Irace86.2.0
Little confused. Accelerator pedal is at 0% and the throttle position sensor typically reads like 20%, so are you saying it reads zero at idle, but does it respond to accelerator pedal inputs, or neither?
Old 08-07-2023, 04:39 PM   #19
Evolbrz
The DBW was not setup correctly and cranking fuel to low and VE down low to high.
I am pleased to annonce the car has officialy started and maintained an idle this has been a long project to get to this and ecumaster has been amazing ...I now officially have a Ecumaster Black EZ30 GenII starter tune for anybody that wants to do this swap and use the ECUMASTER black.
I documented eveything and will be putting all this in a PDF file with all my notes every sensor..everything to this swap in a BRZ...
The Following 5 Users Say Thank You to Evolbrz For This Useful Post:
alex87f (08-10-2023), alphasaur (08-07-2023), Code Monkey (08-07-2023), Irace86.2.0 (08-08-2023), T-Steve (08-24-2023)
Old 08-10-2023, 03:35 PM   #20
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Can we hear the sound of that sweet, sweet flat 6 rumbling into life?
alex87f is offline   Reply With Quote
The Following User Says Thank You to alex87f For This Useful Post:
Evolbrz (08-11-2023)
Old 08-11-2023, 12:28 AM   #21
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Will you be uploading to your YouTube?
Drifter X is offline   Reply With Quote
The Following User Says Thank You to Drifter X For This Useful Post:
Evolbrz (08-13-2023)
Old 08-11-2023, 08:53 AM   #22
Evolbrz
yes I will be filling the rad with coolant and get a video of it idling for you all.
its on stock brz exhaust tho for now but will mod the oem muffler or go no muffler.. stay tuned video will be on my youtube today
The Following 2 Users Say Thank You to Evolbrz For This Useful Post:
alex87f (08-11-2023), whataboutbob (08-13-2023)
Old 08-13-2023, 06:27 PM   #23
gnarjunkie
Drives: '23 GR86, '17 BRZ
Pretty cool swap. Any special reason for going the EZ30 route or just for fun? Any idea the weight difference from the FA20?
gnarjunkie is offline   Reply With Quote
The Following User Says Thank You to gnarjunkie For This Useful Post:
Old 08-13-2023, 07:28 PM   #24
Evolbrz
many reasons actually
1. easy install subaru engine fits right in the oem frame and engine mounts
2. H6 sounds is hard to beat
3. budget the EZ30 is still a affordable engine cause not a lot of people give it the attention to its true potential
4. bolt pattern and ease of keeping oem tranny , clutch, flywheel
5. weigh is 50 pounds more thand fa20 no difference in how the car handles and behavior from oem
6. more low end torque and more power accross the whole rpm band
but If im not satisfied with power I can either add a low boost turbo max 8 psi or so or go with a 4.0 lexus V8 engine that was my next choice I can reuse the ecumaster ECU etc.. not much invested in this build so far it was worth the try
Irace86.2.0 (08-13-2023)
Old 08-13-2023, 09:01 PM   #25
Teseo
Drives: frs
So you just bough the engine, maybe the engine mounts, Stock EZ30 ecu and done? How much cash to turn on key?
Old 08-13-2023, 09:39 PM   #26
Irace86.2.0
Any reason you didn't use a EZ36?
Old 08-14-2023, 10:24 AM   #27
Evolbrz
the 3.6 thinner walls was not recommended if I wanted to low boost it.. plus the sound for some reason the 3.6 does not sound as good. also cheaper to find not a huge difference in power.
Irace86.2.0 (08-14-2023)
Old 08-24-2023, 03:50 PM   #28
Evolbrz
sooo Fuel pumped died... is it common only had 40k I hardwired it to switch to run all the time and well its dead.
So any recommendations ...
08+ STI Brembo swap use 2017 BRZ Rotors? SockMonkey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 08-22-2024 04:57 PM
2017 new BRZ spoiler swap? Zhangy Cosmetic Modification (Interior/Exterior/Lighting) 56 10-18-2021 03:33 PM
Greetings Earthlings - 2017 86 Bumper Swap! SquadRon Scion FR-S / Toyota 86 GT86 General Forum 70 10-26-2018 04:04 AM
2017 diff swap JOE APO Engine, Exhaust, Transmission 97 11-18-2017 08:32 PM
2017 BRZ spoiler swap? rmar93 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-15-2017 09:23 PM
