Old 12-05-2016, 12:34 AM   #1
Zhangy
Drives: 2015 FRS
2017 new BRZ spoiler swap?
The new BRZ spoiler looks amazing, don't you just want it on frs?
Direct replacement on FRS? any idea?
Zhangy is offline   Reply With Quote
Old 12-05-2016, 12:58 AM   #2
novice
novice's Avatar
Drives: Fr-S 2.0 Release
This? http://parts.riverheadbaysubaru.com/...wd=&origin=pla
novice is offline   Reply With Quote
Old 12-05-2016, 02:07 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
The trunk lid has been redesigned to support the new mount points.
Old 12-05-2016, 03:59 AM   #4
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
If your car already has pre-2017 OEM spoiler, you will have more holes on the trunk than 2017 spoiler really needs. Because of its raised pedestal design, 2017 doesn't require the mounting holes on the center whereas pre-2017 has additional 4 extra holes. 2017 spoiler only needs 4 holes (red circled) at each far end of the spoiler and probably one in the middle of the trunk.
Pictures: Courtesy of a member Area86 from a very old post: http://www.ft86club.com/forums/showp...51&postcount=7
Spec C Wannabe is offline   Reply With Quote
Old 12-05-2016, 04:19 AM   #5
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
trunk swap
SuperDave is offline   Reply With Quote
Old 12-05-2016, 03:41 PM   #6
johan
Drives: '14 981CS, '99 NB1
Nope, no hole in the middle. The middle piece you see in photos is not actually connected to the trunk. It is a support piece with a rubber base and corresponding clear plastic protector on the trunk. The two make contact if you use the spoiler to close the trunk due to the deflection in the aluminum wing. It is merely there to keep the spoiler from being damaged due to people grabbing it to close the trunk.
johan is offline   Reply With Quote
Old 12-05-2016, 09:01 PM   #7
Zhangy
Drives: 2015 FRS
Damn this new spoiler will not work for a spoiler swap. The 4 holes in the middle will not be covered up if you put the new one one
Old 12-05-2016, 11:37 PM   #8
Chayce808
Chayce808's Avatar
Drives: 2017 Subaru BRZ Crystal White Pearl
This is what the factory holes look like on a 2017 brz. I don't really care for this wing... Trying to find a wing that will cover these holes....
Sent from my SM-N920V using Tapatalk
Chayce808 is offline   Reply With Quote
Old 12-07-2016, 04:00 AM   #9
Spec C Wannabe
Thank you for sharing the valuable info on the spolier attach points.
From the pictures, it is not an easy task to install the 2017 rear wing due to specific hole shapes that shouldn't be created with a normal drill....
Could you please show the underside of the spoiler base and also what it looks like under the trunk lid?
Thank you.
Old 12-07-2016, 01:13 PM   #10
Chayce808
Chayce808's Avatar
Thank you.
Here's what it looks like under the trunk lid. Two 10mm nuts and a clip. I don't have pics of the underside of the wing.
Old 12-07-2016, 09:52 PM   #11
Spec C Wannabe
Hey Thank alot!
Old 06-15-2017, 01:29 PM   #12
Myriad
Myriad's Avatar
Drives: 2017 86, 2012 Tundra, 1999 Integra
This is an old thread, but it has some great pictures of the US 2017 BRZ spoiler. Which is now also the US Toyota 860 special edition spoiler.
I'm shopping for a new car and looked the 860, but I'm leaning towards the base model hot lava (less flashy orange). One problem is the lack of this spoiler option. The base spoiler is not doing it for me, and very few have them anyway. I'd love to put the all black 860 spoiler on it, if that is a part Toyota could even order. ft86speedfactory.com has an unpainted BRZ one for sale too. To get one with ends painted hot lava would be fantastic, but I understand that is a difficult color to match due to the pearlescent nature of it.
The biggest difficulty beyond painting or ordering, though, is mounting. I understand the new trunks have reinforced plates to keep the metal from flexing, and I'm guessing 86 trunks without an 860 special edition spoiler from the factory do not have this reinforcement. Can anyone confirm this? If it's missing, is this something you can add? Or are these plates under the folds of metal and not accessible? Some of these pics above suggest that.
Thanks,
Myriad
Myriad is offline   Reply With Quote
Old 06-15-2017, 03:46 PM   #13
Darkrune
Darkrune's Avatar
Drives: 2017 86
Thanks,
Myriad
Take a look at both interiors, though. It will be an easy win for the 860. I would have gotten that car, but there were none in the whole state of Florida and I didn't want a yellow edition BRZ.
Question. Does the 17 86 share the same spoiler as the FRS? They look very similar.
Darkrune is offline   Reply With Quote
Old 06-15-2017, 04:07 PM   #14
Myriad
Myriad's Avatar
Yeah, the interior with the orange stitching is fantastic. But that orange paint is pretty bright, and I even like orange as a Flyers fan! I wish it was toned down just a bit. Maybe I should take another look, but they are hard to find. I've only seen it in person once on a road trip, but locally they are starting to filter in so maybe I'll have more chances soon. All that extra money makes me pause, too.
I do believe the stock spoiler for 2017 86 is the same as the FRS.
Myriad
Greetings Earthlings - 2017 86 Bumper Swap! SquadRon Scion FR-S / Toyota 86 GT86 General Forum 70 10-26-2018 04:04 AM
2017 BRZ Front bumper swap BRZoomTX Cosmetic Modification (Interior/Exterior/Lighting) 16 06-01-2018 02:55 PM
2017 Lights, Spoiler on the 2013-2015 Is Always Angry Cosmetic Modification (Interior/Exterior/Lighting) 4 12-14-2016 05:10 PM
2017 BRZ without spoiler? vroomvroom1 BRZ First-Gen (2012+) — General Topics 9 07-18-2016 10:46 AM
Trunk Swap for Spoiler - DFW TX Acree Southwest 11 01-22-2013 08:42 PM
