Old 07-20-2023, 05:53 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Any interest in a T56 swap?
I was googling around and ran across www.grannasracing.com. They make T56 swaps for various cars.
They would be willing to develop a kit if at least "20-30" folks were interested. The kits run $5500-6000 incl the transmission.
If there is enough interest generated on this forum, I will contact Gannas Racing on how we can proceed.
Old 07-21-2023, 02:34 AM   #2
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Mazworks offers a CD009 swap kit already for the FA20. The advantage of the T56 magnum might be lots of gearing options. Both use a custom bell housing, so I'm curious what are you looking for with a T56 over the CD009? The other advantage for using a T56 magnum is that a person could do a LS or 2JZ or K24 swap in the future and run a separate bell housing already available for those engines. Because the T56 magnum requires a custom bell housing, there are multiple options, but this is not the case for the CD009; there are CD009 swap options, but many are adapter plates and not adapter bell housings.
https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
Old 07-21-2023, 09:06 AM   #3
blsfrs
blsfrs's Avatar
Currently, the CD009 is the only way (that I know of) to get a stronger transmission in a twin. IMHO: It would be nice to have more options.
Old 07-21-2023, 09:57 AM   #4
Irace86.2.0
Quicktime might be another company to contact to make a bellhousing adapter.
If this doesn’t catch enough interest, you might want to revisit this topic when companies (if companies) release FI kits for the FA24 platform. At this time, the industry doesn’t seem to be doing much development on products for the second generation like they did for the first generation, including FI. As I see it, that is the biggest problem for you getting interest. FI kits are probably waiting on ECUTEK to finish and maybe they are also doing the CARB route because of the EPA cracking down.
Old 07-23-2023, 10:43 AM   #5
blsfrs
blsfrs's Avatar
I emailed Quicktime. I've messaged this guy too:
https://www.youtube.com/@scantronsgarage/videos
Old 07-24-2023, 02:15 AM   #6
BRX
BRX's Avatar
Drives: Toyota GT86
From my limited experience with T56 swaps, I wouldn't recommend it to be mated with an FA20.
1. Gearing, way too tall for a low torque/high rpm engine like the FA20. You can mix and match to get it as close as you'd want with a short final drive, but all those gear cogs are not cheap.
2. Shifting, the stock BRZ/86 transmission with the right shifter is miles better than any T56 shifter. They're extremely stiff and they don't like to go into or out of gear at high RPM. People use them because they are one of (if not the only) option for high HP manual build not because of their shifting behavior.
3. Clutch options. Due to the limited size of the BRZ/86 chassis and engine/transmission matting surface of the FA20, you are limited to clutches with small pressure plates. Mainly twin or triple disk clutches. It might be fine for some, but a twin disk T56 is usually setup to handle at least +700HP/TQ and I doubt many FA20s are pushing anywhere close to that.
From my research, Z32 clutches should work with a T56 as the input splines are identical on paper but no way to check without trying, I couldn't find anyone who tried on the internet. This might allow you to get a single disk clutch in there...
If you're not planning to swap the engine soon, a CD009 is the better option. Or you could look into a BMW ZF 8HP swap. They're cheap and easy to find. A few Euro shops offer adapters for them and I'm sure they would be happy to help make an adapter for you.
Domi-works are great to deal with and made me an adapter in around 2 months.
BRX is offline   Reply With Quote
Old 08-01-2023, 10:53 AM   #7
blsfrs
blsfrs's Avatar
I got a very definitive answer from QuickTime.(LOL)
Hello,
Thank you for contacting Holley Performance. I'm sorry but I am not able to comment on possible or future products that we could be making. All I can suggest is that you check back periodically with our social media and website as we are coming out with new and exciting products on a regular basis. However, I can add your idea to our ideas bank so that our engineers know that there is a want for this item in the marketplace.
If you have any other questions or concerns please feel free to let us know. We appreciate your business!
Best wishes,
Ben | Communications Specialist | 1-866-464-6553 | www.holley.com
https://f.hubspotusercontent40.net/h...ne%20Image.jpg
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Anyone interest in car swap? Xylon AUSTRALIA 0 12-16-2015 11:14 AM
What interest rate are you getting? doctortt Scion FR-S / Toyota 86 GT86 General Forum 64 03-19-2013 01:53 PM
