Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-20-2023, 10:48 AM | #1 |
Drives: 2023 brz limited 6mt red
2nd gen wheel fitment suggestions
I dont plan on a big brake kit, maybe coilovers down the road but not slammed, I dont want to add spacers, I dont want to modify body panels or deal with rubbing or scrubbing. I want to buy 245/40/17 tires and looking for either flush and or a scooch of poke is ok. If I do lower it it will NOT have the tire up in the wheel well by any means. So I want to be able to lower or keep stock without issues.
What wheel width and offset is best to accomplish this? I understand if I do lower it It will tuck in the fender a little bit. Im looking at rpf1 +45 9" just wanted to confirm of fitment gurus if this is best. Seem to get conflicting info on fitment.com with flush/poke thank you
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
07-20-2023, 05:53 PM | #2 |
Drives: BRZ 2023
It's tricky, +45 9" would fit but with you probably might not be able to add more camber (just camber or lower it).
The Following User Says Thank You to ruturaj001 For This Useful Post: | vindiesel (07-20-2023) |
07-20-2023, 06:47 PM | #3 |
Drives: 2023 BRZ
Director of Rocky Mountain 86CUP
The Following User Says Thank You to Pat For This Useful Post: | vindiesel (07-20-2023) |
07-20-2023, 08:00 PM | #4 |
Drives: 22 Subaru BRZ WRB
I'm running a 17x9 et42 with 245/40/17 and fits perfect with coilovers. It was close to rubbing on the inside on stock suspension.
Sent from my Pixel 6 using Tapatalk |
The Following User Says Thank You to ProGodLegend For This Useful Post: | vindiesel (07-20-2023) |
07-23-2023, 08:39 AM | #6 |
Upon farther research of someone comes across this thread
On stock suspension 2nd gen With a “flush fitment” 17 or 18 inch wheel x 8 inch wide.. run + 35 offset 17 or 18 inch wheel x 8.5 inch wide… run +40 offset Some wheels have goofy offsets like 38 or 42… so depends if you want slight poke or nearly flush. If you run a x9 inch wide wheel on stock suspension you will have rubbing issues and requires aftermarket suspension adjustments to work If any of this needs corrected let me know.
Similar Threads | ||||
Any 3 piece wheel shop repair suggestions or wheel repair shops? | kyle116 | Southern California | 7 | 07-24-2021 12:55 AM |
Looking for Retro Wheel Suggestions | MaverickMonk | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 04-10-2019 08:26 PM |
lightweight wheel suggestions, ~17x7 | wired | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 09-21-2018 08:29 PM |
Wheel repair suggestions? | mrha | Southern California | 10 | 07-16-2013 03:57 PM |
Wheel suggestions... | wootwoot | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-05-2012 01:00 PM |
