Old 07-08-2023, 03:31 PM   #8051
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Random Thoughts - Part III The Search for Spark (No Politics)
Currently designing few forum tshirts… one design I’m thinking is putting some funny forum post w nice come back reply.
Anyone have any posts/comments?
I cant recall the exact post, but theres the
Big brake kit guy
The 5x100 wheel guy
Drag strip guy with the hand-made intake and the tape.
spcmafia is offline   Reply With Quote
Old 07-08-2023, 03:34 PM   #8052
spcmafia
spcmafia's Avatar
DANG, Clipdat, you and ol @NoHaveMSG need to get over it before you give each other an ulcer -
That piece of exhaust pipe will last longer than the rest of the car. Just slap it on there. Hell, it ain't a pressure pipe on a steam boiler or a stress pipe holding up a bridge -
If you wanted to see "ugly welds" you ought to have seen some of my arc welding back in the day, welding galvanized water pipes into a cast iron exhaust manifold to make "headers". Yep, done with an arc welder with one speed (HOT) and one sized rod (LARGE).
Now, don't you two feel better about that piece of pipe?
Man, I didn’t know you worked on the Titanic!
The Following 2 Users Say Thank You to spcmafia For This Useful Post:
humfrz (07-08-2023), NoHaveMSG (07-09-2023)
Old 07-08-2023, 03:35 PM   #8053
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
WHAT am I missing? -
Just messin' with ya.
I had to put some Freon in the car. Only 28k miles and AC blowing hot.
humfrz (07-08-2023)
Old 07-08-2023, 03:56 PM   #8054
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Big brake kit guy
The 5x100 wheel guy
I remember the custom made intake guy. BBK & 5x100 are daily posts lol
Old 07-08-2023, 04:10 PM   #8055
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Ugm, not sure I understand. The steak, for example, would take less than 15 minutes to cook to medium-rare on a grill. Is the Sous Vide method really less time consuming than that?
The thing with sous vide is this:
High end steak houses first started using the method because any cut of steak can be sitting there for hours, ready to go at a minutes notice, and be perfectly cooked. Just take it out, put grill marks on it, and perfect everytime.
Home chef, same. I can get the sous vide going early in the day. Dinner time, when everything else is ready, take steaks out and finish. No longer have to time everything else around the steak.
Bottom line, perfect steaks everytime, and I mean everytime. And I mean perfect medium rare from corner to corner.
Edit: let me add, getting the SV going is same as filling a soup pot.
spike021 (07-09-2023)
Old 07-08-2023, 04:48 PM   #8056
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
@NoHaveMSG Here you go, first three are engine side, last four are catback side.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
humfrz (07-08-2023), NoHaveMSG (07-08-2023)
Old 07-08-2023, 05:17 PM   #8057
So, what are you worried about? The welds will leak exhaust gasses or the welds will not hold and the pipe will break away from the flange?
Asking for Bubba - he wants to know -
Old 07-08-2023, 05:19 PM   #8058
It ain't nice to mess with an old man -
Old 07-08-2023, 07:44 PM   #8059
Clipdat
Proud of BOXER
Clipdat's Avatar
@NoHaveMSG wanted to see what the outside of the flange welds looked like in the same areas that have the partial burn through. I believe he's looking for signs of over penetration in the weld which would indicate a flawed/less than ideal weld.
Seeing as the partial burn through could've compromised the area, I would be "worried" about a crack forming at that spot. Just seems like a point for premature failure.
Doesn't much matter at this point because I also have the Motiv overpipe that I ordered from a different vendor. Upon looking closely at that part, I can see that one part of the inside of a flange weld has evidence of partial burn through as well. But it's a much smaller area and its only one spot. But still.
I guess I can either choose to install these pieces or not.
I'm old and lazy
humfrz (07-09-2023)
Old 07-08-2023, 08:08 PM   #8060
soundman98
ProCrastinationConsultant
soundman98's Avatar
definitely too hot of settings. of course, they were welding 'pop can' pipe to 3/16" flange...
humfrz (07-09-2023)
Old 07-08-2023, 08:15 PM   #8061
Clipdat
Proud of BOXER
Clipdat's Avatar
  • 100-percent stainless steel construction
  • U.S. made RathGibson 2.5-inch tube
  • Custom one-piece Mandrel-belt tubing
  • Signature beautiful brushed finish
  • 3/8-inch thick stainless steel flanges
  • Includes all new gasket and hardware (rear exit uses factory donut gasket)
  • Complete bolt-on
  • Made in U.S.A. with Lifetime Warranty
  • Intended for off-road use only
You mean the walls of the tube/pipe are too thin to weld at such high settings?
I'm old and lazy
Old 07-08-2023, 08:56 PM   #8062
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Doesn’t really look like it is undercut which is good, but it was too hot in some places and you usually don’t want to do so many start/stops.
soundman98 (07-08-2023)
Old 07-08-2023, 09:42 PM   #8063
soundman98
soundman98's Avatar
it looks like my welds. to say, it looks like a new welder that wasn't completely comfortable with the gear, or the settings.
it looks either undercut, or not enough filler rod to me at least. the 1/8th-turn start/stop stuff definitely doesn't help the cause at all.
Old 07-09-2023, 12:45 AM   #8064
Yep, ya gotta be quick to do that -
soundman98 (07-09-2023)
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 11:00 AM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-26-2017 11:33 PM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 07:35 PM
