Old 04-09-2019, 11:02 AM   #113
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Originally Posted by dave- View Post
Has this been confirmed or updated to be suitable for RHD?
Can it be configured to vent to atmo? My car is track only and boosted, have found my current tiny mishimoto can with the outlet plumbed back to inlet infront of the turbo is sucking the oil out of the can?
The drain option would be really good too
At this time it is not available for RHD as the brake booster is in the way IIRC. We have not scienced out a mounting solution as we don't have access to a RHD vehicle.
VerusEric is offline   Reply With Quote
Old 07-29-2019, 01:36 PM   #114
BRZ FTW
Drives: 2017 Subaru BRZ
@VerusEric
Just installed this last night. For an NA install, is it possible to leave the PCV valve in the stock location? If not, what is the purpose of relocating it?
Also, My AOS didn't come with caps for the coolant ports. Are these okay to leave open/exposed?
BRZ FTW is offline   Reply With Quote
Old 07-29-2019, 02:32 PM   #115
VerusEric
VerusEric's Avatar
Originally Posted by BRZ FTW View Post
@VerusEric
No. For the unit to work as intended; the PCV valve must be installed into the AOS per the instructions.
Yes, that is fine. We do not ship them with caps for the coolant ports as there is nothing bad about them being exposed. The unit is fully anodized so it should not corrode or degrade.
The Following User Says Thank You to VerusEric For This Useful Post:
BRZ FTW (07-29-2019)
Old 07-29-2019, 02:33 PM   #116
BRZ FTW
Thanks!
Old 12-02-2019, 11:09 AM   #117
VerusEric
VerusEric's Avatar
Cyber Monday is one of the few times we offer a discount on our items all year. Now is a great time to look into some of our parts if you were interested!
Coupon code during checkout is "VerusMonday10"
Old 03-30-2020, 02:26 PM   #118
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by chewbacca View Post
please see and learn from this link:
Did you really need to bump every thread related to catch cans?
MS, CSCS, TSAC-F, CPT
Old 09-04-2020, 11:47 AM   #119
Jo0
Drives: '17 CWP Limited w/ PP
For those who have the Drain Back Kit, are you seeing your 90Deg fitting connecting to the check valve backing out over time? Does your 90Deg fitting also rub against your sound generator tube?
Mine does both.Wondering if anyone has fixed it without going out and (re)making a hose with enough slack. It's just -6AN right?
Jo0 is offline   Reply With Quote
Old 07-05-2021, 09:25 AM   #120
VerusEric
VerusEric's Avatar
Are you tightening the fitting enough? I have not heard of anyone with backing out issues.
Those hose and fittings are all -6an so yes, you can easily remake the hose if you would like to.
Old 04-03-2022, 11:17 PM   #121
bhmax
Drives: 13 BRZ, 17 Focus RS
I’ve been running mine on a NA setup. I’m installing a Harrop SC now. It looks like I could run the “outs” to the front of the SC and to the airbox. Is there any issue with taking the outs, teeing them together, and then just running to one of those locations?
bhmax is offline   Reply With Quote
Old 04-06-2022, 12:16 PM   #122
Chuckls
Moutain Runner
Boosted applications it's best to run the outs as VTA. So you can T the outs together and route to an area that VTAs like above the transmission.
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
bhmax (04-06-2022)
Old 04-06-2022, 01:48 PM   #123
KillerBMotorsport
KillerBMotorsport's Avatar
Why wouldn't you run in through an AOS or catch can and into the compressor inlet side? This way you'd be pulling crankcase vacuum, which is going to be better than building crankcase pressure (VTA).
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
bhmax (04-08-2022), tomm.brz (04-11-2022)
Old 04-11-2022, 06:55 PM   #124
Chuckls
Moutain Runner
Im no expert. It's just been the general consensus in the boosted application groups I've been privvy to.
Old 04-11-2022, 10:03 PM   #125
tomm.brz
Drives: brz 2017 hksv2
general wrong consensus, closed loop system is best, you need that vacuum in the pcv side to proper vent
Old 07-07-2023, 06:54 AM   #126
VerusEric
VerusEric's Avatar
It's best to have the system pull a slight vacuum on the crankcase. We have found with turbo applications, that *sometimes* you can pull too much oil/vapor out of the crankcase and overwhelm the can. That is the only time we recommend VTA, but it is generally at over 400whp.
The oil is also coming from the rear port primarily (OEM PCV Valve location).
tomm.brz (07-07-2023)
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
Raceseng | Revo Pulleys Information and Release Raceseng Engine, Exhaust, Transmission 3 10-09-2016 11:01 AM
