#113 | |
Drives: BRZ, STI, GT350R, Supra, 987.2
#114 |
Drives: 2017 Subaru BRZ
@VerusEric
Just installed this last night. For an NA install, is it possible to leave the PCV valve in the stock location? If not, what is the purpose of relocating it? Also, My AOS didn't come with caps for the coolant ports. Are these okay to leave open/exposed? |
#115 | |
Yes, that is fine. We do not ship them with caps for the coolant ports as there is nothing bad about them being exposed. The unit is fully anodized so it should not corrode or degrade. |
| The Following User Says Thank You to VerusEric For This Useful Post: | BRZ FTW (07-29-2019) |
#116 | |
#117 |
Cyber Monday is one of the few times we offer a discount on our items all year. Now is a great time to look into some of our parts if you were interested!
![]() ![]() Coupon code during checkout is "VerusMonday10" |
#118 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Did you really need to bump every thread related to catch cans?
#119 |
Drives: '17 CWP Limited w/ PP
For those who have the Drain Back Kit, are you seeing your 90Deg fitting connecting to the check valve backing out over time? Does your 90Deg fitting also rub against your sound generator tube?
Mine does both.Wondering if anyone has fixed it without going out and (re)making a hose with enough slack. It's just -6AN right? |
#120 | |
Those hose and fittings are all -6an so yes, you can easily remake the hose if you would like to. |
#121 |
Drives: 13 BRZ, 17 Focus RS
I’ve been running mine on a NA setup. I’m installing a Harrop SC now. It looks like I could run the “outs” to the front of the SC and to the airbox. Is there any issue with taking the outs, teeing them together, and then just running to one of those locations?
#122 |
Moutain Runner
Boosted applications it's best to run the outs as VTA. So you can T the outs together and route to an area that VTAs like above the transmission.
| The Following User Says Thank You to Chuckls For This Useful Post: | bhmax (04-06-2022) |
#123 |
Why wouldn't you run in through an AOS or catch can and into the compressor inlet side? This way you'd be pulling crankcase vacuum, which is going to be better than building crankcase pressure (VTA).
#124 |
Moutain Runner
Im no expert. It's just been the general consensus in the boosted application groups I've been privvy to.
#125 |
Drives: brz 2017 hksv2
#126 | |
The oil is also coming from the rear port primarily (OEM PCV Valve location). |
| The Following User Says Thank You to VerusEric For This Useful Post: | tomm.brz (07-07-2023) |
| Verus Engineering High Performance Radiator - Gauging Interest | VerusEric | Engine, Exhaust, Transmission | 90 | 07-08-2023 07:43 AM |
| Verus Engineering Rear Wing Development | VerusEric | Tracking / Autocross / HPDE / Drifting | 203 | 07-05-2021 09:15 AM |
| Verus Engineering Billet Transmission Beta Tester Run | VerusEric | Engine, Exhaust, Transmission | 62 | 04-26-2020 01:44 PM |
| Verus Engineering Carbon Thermoplastic Splitter Components | VerusEric | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 11-26-2017 05:23 AM |
| Raceseng | Revo Pulleys Information and Release | Raceseng | Engine, Exhaust, Transmission | 3 | 10-09-2016 11:01 AM |
