Old 06-22-2023, 11:54 PM   #1
SlwFRZ86
SlwFRZ86's Avatar
Drives: 17 brz limited
Question OEM 22 Oil Cooler
Hello everyone,
I was researching oil coolers for my brz. I stumbled upon this video.
He uses a 22 BRZ oil cooler part number 21311AA220.
anyone have experience doing this mod?
what are the temps looking like?
Is this mod good for track use or just use oil cooler like perrin/skunk2 ?
SlwFRZ86 is offline   Reply With Quote
Old 06-23-2023, 02:18 AM   #2
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
It's similar to the Forester oil cooler that has been talked on the forums for a decade.
It is not enough for track use in high ambient temp days in my opinion.
A standard well placed/ducted oil cooler will be more effective for track use.
villainous_frx is offline   Reply With Quote
Old 07-01-2023, 07:03 PM   #3
ajaxburger
ajaxburger's Avatar
Drives: 2017 BRZ Limited Perf. Pack
Second this. Seems like it would definitely help if you had high temps while daily driving in hot weather although for the cost it's more likely worth it to purchase a quality aftermarket cooler with a radiator and proper cooling loop.
zoom zoom... wait wrong company
ajaxburger is offline   Reply With Quote
Old 08-05-2023, 11:05 PM   #4
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I've been thinking about doing this mod for my autocrossed BRZ, possibly when moving up to STX from street class.
The real benefit to a kit like this is being OEM, but also that it's more of an engine oil warmer and cooler. Warms it up to get your oil temp where it needs to be for your first run or just quicker when street driving. Also cools things down a bit, but not as much as a dedicated oil cooler.
I don't like oil coolers for street cars because the oil temp takes too long or never gets up to where it should be depending on the kit. Also, it's another line to get clogged, hose to come off, or rock to hit the cooler in the front and boom, there goes oil pressure and your oil... and engine.
This is a pretty tame kit, but work, just don't expect tons of cooling. I think I saw a video and it was like 10 degrees or so when romping on it in the canyons or heavy street use. Given you're not a track hitting 260+ degrees, the max you should be hitting is about 230-240.
So eh. I couldn't justify the cost vs the 10 degrees or so it was doing on the videos I watched. Maybe in the future.
cmiovino is offline   Reply With Quote
Old 08-06-2023, 04:08 PM   #5
N_Raged
Drives: 2019 BRZ Sport-Tech RS
I have both the Forester heat exchanger and the Jackson Racing oil cooler stacked on my 2019 BRZ. Quick warm-ups and good cooling at the top end. However I swapped the thermostat with mishimoto's 200F thermostat because the Jackson Racing ~185F thermostat opens way too soon - overcooling the oil during highway cruising.
To address the concern about stone chips damaging the core, I installed a mesh grille in the bumper opening to block bigger objects from hitting the oil cooler and radiator.
N_Raged is offline   Reply With Quote
Old 08-06-2023, 05:16 PM   #6
Teseo
Drives: frs
Originally Posted by SlwFRZ86 View Post
Hello everyone,
I have it. Temps are the same as without it but doesn't go high in spike like no having it (think as a buffer). Not bad at all considering you could source parts locally at dealership
Old 08-06-2023, 05:17 PM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
has anyone attempted a finned aluminum oil pan? i would figure the gains would be pretty close.
Old 08-10-2023, 05:27 PM   #8
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
Or work the opposite absorbing all the heat from everyone’s un coated and un wrapped headers!
Old 08-10-2023, 06:23 PM   #9
7 skulls
Drives: 2014 scion frs
I used an aluminum, multi-fined product available from RHD Japan that can stick to any metal surface with a special heat transfering glue. Lots of fins with a ton more surface area, covered my oil pan. It made no difference.
7 skulls is offline   Reply With Quote
Old 08-10-2023, 09:55 PM   #10
Grady
Grady's Avatar
A heat sink needs a good temperature differential to work. I insulated my pan, that worked.
Question about low mount oil cooler askho Engine, Exhaust, Transmission 8 06-25-2020 07:25 PM
Age old Oil Cooler Kit question mg92p Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 05-16-2020 12:52 AM
Forrester oil cooler with oil to air cooler question ? sroby Engine, Exhaust, Transmission 20 08-01-2019 09:49 AM
Oil cooler question Qwimby1 Engine, Exhaust, Transmission 16 04-20-2018 12:08 AM
Question about Greddy oil cooler Captain Snooze Engine, Exhaust, Transmission 3 09-10-2012 03:40 AM
