Old 06-25-2020, 05:01 AM   #1
askho
Drives: 2013 Subaru BRZ
Question about low mount oil cooler
Hi All!
I just bought an oil cooler that mounts to the bottom of the front fascia and another ft86 owner mentioned that it would be a good idea to mount it higher up like underneath the bumper crash beam due to a higher chance of it ripping off in a track accident.
So my question is has anyone actually seen an oil cooler get destroyed by going slightly off track due to it being mounted on the lower front fascia or is this just an irrational fear?
Thanks!
askho is offline   Reply With Quote
Old 06-25-2020, 11:30 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I've never seen it happen, just it mentioned as a possibility. I have had a few high speed off tracks and never damaged a cooler so I don't think it is too much of a concern. I do plan on mounting it to the crash beam in the future so it is hit with cleaner air. Mounting to the lower fascia it is a little masked by the lower part of the bumper.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DarkPira7e (06-25-2020), norcalpb (06-25-2020)
Old 06-25-2020, 11:54 AM   #3
Code Monkey
Drives: Subaru BRZ
^ +1
Code Monkey is offline   Reply With Quote
Old 06-25-2020, 03:53 PM   #4
askho
Awesome thanks for clearing up my concerns!
Old 06-25-2020, 04:00 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Pretty much all the oil cooler failures I've heard of was rocks or debris punching a hole in it and losing oil.
Old 06-25-2020, 06:25 PM   #6
norcalpb
norcalpb's Avatar
Does anyone know if there are any negative affects from mounting an oil cooler “upside down” with the nozzles facing down? This is the way I see it mounted to the crash beam but I’ve read negative things on other car forums.
Old 06-25-2020, 06:31 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
For our application I don't see it being an issue as the sandwich plate is so high. The issues I have seen are all configurations where the cooler is higher then the feed/return line positions so it can drain back into the pan when the engine is shutoff, or cause a brief low oil pressure situation while the engine tries to fill it back up on startup.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 06-25-2020, 07:24 PM   #8
norcalpb
norcalpb's Avatar
Awesome, that’s what I wanted to hear.
Do you know if it’s ok that I rotate my oil cooler 180 degrees, so the back of the cooler is the new front?
Old 06-25-2020, 07:25 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As far as I can tell they are non directional. I have a setrab 613 core. I don't think orientation matters too much.
Age old Oil Cooler Kit question mg92p Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 05-16-2020 12:52 AM
Forrester oil cooler with oil to air cooler question ? sroby Engine, Exhaust, Transmission 20 08-01-2019 09:49 AM
Where to mount thermostat for AT cooler Tristor Engine, Exhaust, Transmission 14 09-04-2018 06:10 PM
Transmission mount question Bullnettles Engine, Exhaust, Transmission 2 05-28-2013 12:22 PM
Trans/Motor Mount question DanoFA20 Engine, Exhaust, Transmission 5 03-02-2013 03:16 PM
