#29 | |
Rust bucket enthusiast
I would recommend new o rings for the cam position sensors. 2 of mine (both bottom) started leaking with the new front cover
| The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | blsfrs (05-24-2023), Ultramaroon (05-24-2023) |
#30 |
Drives: BLue 2013 frs
Any updates on this? Been having low oil pressure issues as well. Cant seem to figure it out. Had a shop go through the motor and replace mains and rod bearings. Shop couldn’t find anything bad that has to do with oil pressure. I had the front timing cover replaced and get the reimax oil pump installed. Still bad oil pressure=(, at this point im only thinking about the cam sprockets. Could those cause bad oil pressure? I sometimes hear this extra rattle or tapping noise on BANK 2 near the high pressure fuel pump.
#31 | |
Drives: 2013 frs base
I've got my new timing cover. It may not help but I'm going to do a little porting. I'm going to use the stock pump. I'm guessing that you verified the accuracy your op gauge? I haven't heard of the cam sprockets being implicated in low op. Were the "O"ring for the timing cover replaced? |
#32 | |
Yes, i purchased a mechanical pressure tester and verified my oil pressure. Its still like under or around 5psi psi when hot. =( shoot i remember seeing an old post a few days ago from AVOturbos that stated something about oil pressure those little plates behind or something close to that. Ill try to find it later today. Thanks for the reply! Edit: i think the shop put in new o rings. They charged me for a engine gasket kit |
#33 | |
#34 | |
Drives: Crapcan
#35 |
Honestly no idea. Motor had like 3k on it when i noticed. The shop did say the cams were some scoring but i felt that was those were effects of the low oil pressure, not the cause. I wish i noticed it or monitored my oil pressure more often.
| The Following User Says Thank You to fableluke For This Useful Post: | blsfrs (06-16-2023) |
#36 | |
This is good info. Thanks! |
#37 | |
"The bores were too big". Was this the oem engine? |
#38 | |
A little frustrating the shop is asking me to drive the car back but the 1st time i dropped off the bare longblock for them to inspect and find any oiling issues. Maybe im just a noob but wouldnt a machine/auto shop find obvious signs of oiling issues if they went through the entire longblock? They asked me to take it back running to check all of that. But hey maybe im salty i forked over 4k and my low op issues is still there. No i believe its an IAG block. I bought it off a buddy for a good deal but he said might have issues. Its why i wanted a shop to inspect it. Edit: found that old post about that cam sprocket intake plate thing and oil pressure. https://www.ft86club.com/forums/show....php?p=1802327 Last edited by fableluke; 06-16-2023 at 01:37 PM. |
#39 | |
I wonder if they checked the oil pickup screen? After talking to the shop, the car will probably need to be trailered or taken on a flatbed back to the shop. |
#40 | |
Great, i forgot they didnt fill out the bearing clearances….well ill have to ask about that |
#41 | |
It also begs the question: What did the shop do about it? |
#42 | |
| The Following User Says Thank You to fableluke For This Useful Post: | blsfrs (06-18-2023) |
| Oil pressure | Limitless_BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 76 | 06-08-2021 12:25 AM |
| oil pressure | Legend@wheels | Engine, Exhaust, Transmission | 23 | 12-25-2018 11:45 AM |
| best tire pressure gauge (tire pressure question) | steveholt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 03-21-2015 10:27 PM |
| Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
| Oil Pressure.. too low? | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 65 | 08-24-2013 12:43 AM |
