Drives: 2015 FR-S
Creaking sound
So had a tire blow out on the highway and ever since I’ve been getting this popping/creaking sound in my front driver side wheel well. It happens mostly when the weight is shifting to the left side of the car (right turn, lowing off jack, , breaking, ext). I got under the car to see if there was anything major I could notice any play anywhere. Nothing that I noticed. Had my buddy moving the wheel seemed like the ball joints are fine (as far as I could tell). Tried lubin up metal on metal contacts, no change in sounds. Honestly, stumped. Any idea, advise, wisdom, anything??
Thanks in advance! |
#2 |
Strut bearing?
| The Following User Says Thank You to Tokay444 For This Useful Post: | norcalpb (06-01-2023) |
#3 |
Drives: 2013 BRZ HKS Turbo
Did you disassembly/repair any part of the suspension when you had the tire blow out? Or literally, remove wheel, replace tire, reinstall wheel?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
#4 |
What suspension do you have?
#5 |
Drives: 2015 FR-S
Just now seeing these, my notifications mustve been off. I didn’t repair or disassemble, did consider it to grease metal on metal contacts but i feel like that wouldnt be permanent fix. There is an aftermarket suspension and lowering kit.
I had my car realigned recently to see if the tire blowing out through the alignment off. The guy says when you lower the car the suspension doesn’t have room so it’s goinv to make noise… I feel like that’s not the case Last edited by SBFRS; 06-09-2023 at 10:57 PM. Reason: Add info |
#6 |
Drives: 2015 FR-S
Not sure the exact suspension either, one of the only things I didn’t do myself. I’ll see if I can figure it out
#7 |
ProCrastinationConsultant
aftermarket top hats installed?
#8 |
Drives: 2015 FR-S
I’d have to check they may be oem, if I remember correctly
| Steering Wheel Creaking Sound | Swolzee | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-06-2022 10:17 PM |
| Old creaking sound when turning | pher.da.rico | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-26-2020 08:15 PM |
| Trunk creaking | alex87f | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 03-03-2020 08:56 PM |
| Creaking Chassis? | weederr33 | Issues | Warranty | Recalls / TSB | 4 | 04-07-2017 08:38 PM |
| Sway Bar Creaking | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-16-2015 01:28 PM |
