Old 06-04-2023, 10:36 AM   #1
midnitz
Drives: white fr-s
Will my engine be alright? Coolant gauge went high and lost 3 of coolant
I was a noob.
Changed the coolant but didnt put the bleeder valve back on and drove off. The cool temp gauge reached 3/4 before the HOT TEMP (teel color in the picture). Car didnt throwout any CEL.
But about 3L of coolant did evaporated. I Added back the coolant and car seems to run fine. No white smoke.
But I was wondering what longer term damage have I done.
Thanks for any input!
midnitz is offline   Reply With Quote
The Following User Says Thank You to midnitz For This Useful Post:
humfrz (06-05-2023)
Old 06-04-2023, 10:37 AM   #2
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
How does your dipstick look?
ybotspawn is offline   Reply With Quote
Old 06-04-2023, 10:46 AM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
how often do you check your coolant level?
my car did this back in early 2014, about 4-6 months after getting it. was doing my first oil change fluid checks, and found my coolant bottle entirely empty. brought it in for warranty, they couldn't find anything wrong. refilled/burped system, it fluctuated once afterwards. i added more superblue subaru spec coolant, it hasn't really changed since.
humfrz (06-05-2023)
Old 06-05-2023, 03:54 PM   #4
Originally Posted by midnitz View Post
I was a noob.
Changed the coolant but didnt put the bleeder valve back on and drove off. !
that was dumb! Pay attention to what you're doen.
Your car will most likely be OK.
This used to happen quite often back in the old days. Just take off your T-shirt and wrap it around the radiator cap and open slowly. Check for a split hose and if you find one, duck tape it up.
Dip some water out of a ditch and fill the radiator. Not to worry if the water is dirty or has some trash in it, the trash will stop small leaks.
Clipdat (06-05-2023), soundman98 (06-05-2023)
Old 06-05-2023, 04:19 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
lol Roger. Never change.
Originally Posted by humfrz
I'm old and lazy
humfrz (06-06-2023)
Old 06-05-2023, 06:54 PM   #6
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
There likely isn't any long term damage.
My dad was driving me back from the emergency room once in our 2000 Camry and going up a long hill with a bunch of turns, the coolant gauge literally was pegged to the max. I told him to immediately pull over and put the hot air on, but he kept going because "we're just a few miles from home". Drove another ~2.5 miles with it more or less pegged there and sometimes fluctuating down partway.
Got home, engine was clicking after turned off - you know, from all the heat. You could feel it radiating off the engine with the hood up in the garage a ton, way more than normal. Coolant overflow was empty.
Filled it up, burped the system, it's still running just fine. Never just keep driving, but at least with a Toyota inline four, the sucker kept going with zero issues.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
humfrz (06-06-2023)
Old 06-13-2023, 10:30 AM   #7
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
As others are saying, you're likely fine, even long term. The only thing to note is that the heat puts more strain on your head gasket. But you didn't get excessively hot either, so you're likely fine even in the long run. I've had coolant temps go up high in a few old used vehicles I've owned in the past. As long as this isn't something you allow on a regular basis and take care of the problem quickly, you shouldn't have to worry.
Dzmitry is offline   Reply With Quote
Car won't start, engine coolant high temperature? TeaFee Issues | Warranty | Recalls / TSB 28 07-17-2021 09:00 PM
How is it possible to lose coolant, if the coolant system in a car is a closed loop, ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 09-12-2020 02:09 AM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Coolant lost after autox? nyfries Engine, Exhaust, Transmission 24 09-15-2014 10:07 PM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
