| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Toyota GT86
Shelf life for open brake fluid
Once you crack the seal on brake fluid is it safe to use again after its been sitting for a few months ?
I am looking to bleed my brakes tomorrow and would like to finish off what's left of my castrol SRF plus open another new bottle that I would plan on using again next time I bleed the brakes any issues with that plan ?? Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#2 | |
Famous Potatoes
Drives: '15 ultramarine
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | autoracer86 (06-04-2023), soundman98 (06-04-2023) |
#3 |
Drives: 2013 FRS
https://blog.amsoil.com/dot-3-and-do...he-difference/
Mentions dot3 can absorb 2% per year, the more moisture in the brake fluid the lower the boiling point will be. I won't use old bottles myself, especially if it's going on track. |
#4 | |
Drives: Toyota GT86
Thanks for the link
#5 |
Drives: Toyota GT86
Okay I used some of the new bottle mixed with the rest of the old bottle. Job done and the brakes feel great. We will see how they hold up long term
#6 |
Drives: Scion FR-S 10 Series
Plastic wrap over top of the opening and then putting the cap on top of that might be an effective moisture barrier.
#7 |
Drives: frs
Put the un-used bottle in your drawer
#8 |
ProCrastinationConsultant
| The Following User Says Thank You to soundman98 For This Useful Post: | Clipdat (06-05-2023) |
#9 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
instructions unclear, everything is in a bunch now.
| The Following 3 Users Say Thank You to villainous_frx For This Useful Post: |
#10 |
If the cap is tight it can only absorb what moisture is inside the bottle. 2 months 2 years does not make any difference. You will be fine. If you store it outside with the cap off I would not use it.
| The Following 3 Users Say Thank You to Grady For This Useful Post: |
#11 |
Drives: BRZ, Canyon
I have a bottle of Stoptech SRF660 fluid that was opened ~4 years ago. Just tested it a few days ago with test strips. The strip barely showed any contamination at all. It probably is at least 98% good. Bottle was sealed with just the regular cap and stored in my garage.
| The Following 5 Users Say Thank You to Sevs753 For This Useful Post: | autoracer86 (06-09-2023), Dzmitry (06-14-2023), jflBRZ (06-27-2023), Ohio Enthusiast (06-08-2023), soundman98 (06-08-2023) |
| Tyre storage and shelf life. | Captain Snooze | Tracking / Autocross / HPDE / Drifting | 1 | 07-02-2019 08:36 AM |
| I want this in my life (brake duct) | chaoskaze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 62 | 03-14-2018 11:47 PM |
| OEM Brake Pad Life | Cal3000 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 10-03-2014 06:39 AM |
| Track day brake life? | transition | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-03-2014 04:57 AM |
| Brake Fluid shelf life? | VoiD | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-02-2013 06:17 PM |
