2013 Scion FRS Exhaust Manifold bolts
So I just resealed my timing cover. Found that my exhaust manifold couldn't be removed due to at least one bolts is cross threaded in the head. The only time the exhaust was ever off was when the valve recall was done back in 2019-2020.
#2 |
Drives: 2013 frs base
Could you send a picture of the "bolts"? Generally, there are 3 studs on each head with nuts to hold the manifold on. The studs are fairly long so it would have been quite an effort to run them all the up cross threaded. I've had older Subbies where bolts were used. Something could have gotten messed up when the recall was done.
#3 |
Drives: Crapcan
We don’t have manifold bolts, we have studs that are screwed into the head. Studs stay in the head unless damaged and need replaced. The manifold is held on with nuts. Likely just corroded or they flattened some threads when putting the manifold back on. Use a 6 point socket and be patient with it. Possibly may need some heat if it is just corrosion.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (06-04-2023), soundman98 (06-04-2023) |
#4 | |
Drives: 2014 GT86
| The Following 2 Users Say Thank You to churchx For This Useful Post: | NoHaveMSG (06-05-2023), soundman98 (06-05-2023) |
#5 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (06-05-2023) |
#6 |
I may just do that. Take my time and heat it up. I appreciate the help guys. I may document this repair and put it up on here. Thanks again!
| The Following User Says Thank You to jetrex For This Useful Post: | blsfrs (06-06-2023) |
| FS: US-CA: $50 - OEM 2013 Scion FR-S Catback exhaust | microSDHC | Engine, Exhaust, Bolt-Ons | 0 | 08-17-2020 07:28 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 11:40 AM |
| WTB Magnaflow Catback exhaust 2013 scion frs | Chase1996 | Want-To-Buy Requests | 1 | 09-30-2015 09:44 PM |
| GReddy Supreme SP Cat Back Exhaust Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 7 | 07-15-2015 05:21 PM |
| Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 21 | 06-03-2015 03:21 PM |
