timurrrr
Old 05-25-2023, 03:01 PM   #1135
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Dzmitry View Post
Doesn't make sense. Sure, I agree 100% that he may have saved his engine by shutting off the vehicle ASAP. But warranty wise, whatever the problem was, it existed regardless.
"Save" is a relative term. Likely if it was warranty, they would just throw a short block in it and not rebuild it anyway. As much of a PITA it is labor wise to rebuild a boxer bottom end, it's usually not any more cost effective then just replacing it. Might have just saved head damage at best.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (05-30-2023), soundman98 (05-26-2023)
Old 05-25-2023, 03:07 PM   #1136
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by DocWalt View Post
There's a big hole in the block because he didn't stop driving and it eventually seized a rod to the crank.
That's exactly what would happen on any spun bearing.
Oh really? Not all the time.... Matter of fact I have an 53k mile engine in my garage right now from a 2013 complete FRS that I bought because the engine was knocking. Oil pickup was plugged from a shoddy valve spring recall. I drove the car home knocking, 40+ miles at Interstate speeds. Rods never let go....matter of fact it still turns over.
I'd bet there is a whole lot more to this story...
lack of oil from owners own maintenance, tuned ecm, data recorder shows something abusive...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
norcalpb (05-25-2023), soundman98 (05-26-2023)
Old 05-25-2023, 03:15 PM   #1137
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
My FA20 threw the rod after spinning the bearing. Lost oil pressure from kicking out a rocker arm before a downhill blind right hand corner. Tried to nurse it to a safer spot on track to pull to the side and it went.
DocWalt (05-26-2023), soundman98 (05-26-2023)
Old 05-25-2023, 03:32 PM   #1138
Tokay444
I can't even imagine them swapping heads over.
Old 05-25-2023, 03:33 PM   #1139
Tokay444
Keep running it and let us know how long it goes without windowing the block, because it will.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
DocWalt (05-26-2023), ka-t_240 (05-29-2023)
Old 05-26-2023, 11:20 AM   #1140
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Keep driving it and let us know how that goes.
Old 05-26-2023, 11:39 AM   #1141
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by cmiovino View Post
The above one is a hard one to watch because as the comments are saying, he's not beating on the car. It's certainly more of a novice, first track day type of experience going on, not time trials or anything.
He does note he did a fresh oil change with 5w-30 the day prior to this. It's really unknown until an engine teardown is done to confirm if there's a crap ton of silicone clogging the pickup, but I wouldn't completely rule out the possibility the oil change was underfilled.
I'm not attacking the owner, but I've seen a lot of people think they're all good to go, like putting on a new filter, filling up to the "full" dot, and calling it day. As much as I autocross, I prime the system, start the car, drive it around, and come back to top up whatever might be needed. A lot of times people are running their cars a quarter of a quart under that full mark, or more. Which might be ok for the street, but then toss some good G's on the track at it and you could put yourself at risk.
But who knows. All just speculation. Can't simply just blame it on RTV and Toyota/Subaru and call it a day. There are many pickups out there with a good bit in/on them and limited failures.
Is 5w-30 specified for standard use in the owners manual?
It's not on the fa20, and has been grounds for warranty denial in the past
It's also not very conducive to be using a track video for reasons to not void a warranty
Old 05-26-2023, 12:57 PM   #1142
Tokay444
"Thanks for buying a GR86. Here's a free track day since we want people to believe we built this car for good safe fun. Just don't use it and take a video or your warranty is void."
See how ridiculous it sounds?
new2subaru (05-27-2023), WolfpackS2k (06-06-2023)
Old 05-26-2023, 01:11 PM   #1143
soundman98
soundman98's Avatar
That isn't at all factual though.
1. There's no indication he ever used the free track day.
2. There's multiple indications he bought it as a dedicated track toy in the drive article.
3. He specifically states it's a warm up lap for later laps. As well as indicating he's been on the track before.
4. Toyota endorses/warranties the car for (1)one track day not multiple.
There's got to be a limit somewhere...
Old 05-26-2023, 01:39 PM   #1144
Tokay444
Hilarious.
The Following User Says Thank You to Tokay444 For This Useful Post:
Old 05-26-2023, 05:10 PM   #1145
soundman98
soundman98's Avatar
but even if we ignore the toyota/track day thing, he acknowledges he filled the motor with 5w-30, which it should be getting 0-20 by their manual, which is absolutely enough of a reason to deny warranty coverage.
Clipdat (05-26-2023)
Old 05-26-2023, 06:44 PM   #1146
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Voided warranty due to unplugged active sound control
Neon lights under car
Stretched tires that were bald only on .25” of tire on chrome wheels
And a license plate that said “moar rtv”
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 05-26-2023, 07:29 PM   #1147
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
lol
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
bcj (05-27-2023), vindiesel (05-26-2023)
Old 05-27-2023, 02:06 PM   #1148
Dake
Dake's Avatar
Has the manual changed? The old manual still said that was a permitted formulation.
Dake is offline   Reply With Quote
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 01:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 04:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 11:11 AM
