Old 05-25-2023, 02:20 AM   #1
Limitz
Drives: Black Scion FR-S
Need help choosing an intake
I’m trying to get a cold air intake but is there any that does not require a tune ? And for those that do require a tune, can you tune it yourself with an open flash tablet ? I honestly just want to have intake noises tbh…. Right now I’m between the injen intake or the grimspeed
Limitz is offline   Reply With Quote
Old 05-25-2023, 02:34 AM   #2
makinen
makinen's Avatar
Drives: Toyota 86
For the noise, chopping the snorkel is enough.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 05-25-2023, 03:44 AM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Good drop in filter and put the money into other things
The Following 3 Users Say Thank You to Bonburner For This Useful Post:
Clipdat (05-25-2023), NoHaveMSG (05-25-2023), RToyo86 (05-25-2023)
Old 05-25-2023, 06:49 AM   #4
Lantanafrs2
Drives: 2013 frs red
None of them require a tune but some of them will confuse the tune you have
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Limitz (05-25-2023)
Old 05-25-2023, 07:50 AM   #5
new2subaru
Weight Weenie
Drives: 15 FR-S
You could splurge for a TRD. Can’t go wrong with OEM
The Following User Says Thank You to new2subaru For This Useful Post:
NWFRS (05-29-2023)
Old 05-25-2023, 07:51 AM   #6
tomm.brz
Drives: brz 2017 hksv2
grimmspeed messes less with maf if you don t want to tune.. but in reality they all will mess with it and require a tune to have spot on afr
The Following 3 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (05-25-2023), DocWalt (05-25-2023), Limitz (05-25-2023)
Old 05-25-2023, 09:54 AM   #7
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Inlet tube + high flow filter and call it a day.
The Following 4 Users Say Thank You to RToyo86 For This Useful Post:
Clipdat (05-25-2023), Limitz (05-25-2023), NoHaveMSG (05-25-2023), SCFD (05-25-2023)
Old 05-25-2023, 11:18 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The stock intake is a cold air intake.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Clipdat (05-25-2023), Teseo (05-26-2023), whataboutbob (05-25-2023)
Old 05-25-2023, 11:54 AM   #9
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
If ALL you want is sound you could update the Sound Generator.
TRD sell a 3-Pak but they seem pricy for what you get. I have seen used ones posted for sale on occasion.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is online now   Reply With Quote
Old 05-25-2023, 04:37 PM   #10
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I've played with intakes on various NA Subaru boxer engines over the years. I do get the sound you're chasing - basically an exposed cone filter. Which in short ram or "hot" intake variations are bad for power and can even lead to detonation in extreme heat instances. Cold air intakes I've seen suck up water and hydrolock engines in a few cases, plus the filter sometimes is too far away for the sound you want.
In either case, the cone filters generally need full intakes to work, which ALL should be tuned for because ALL vary the MAF scaling. Now, whether or not the ECU can adjust for any variances is how manufactures get away with saying "no tune needed" sometimes. The problem is all deviate away from the MAF scaling tables, some more than others.
As others have said, stock intake with a drop-in filter is the way to go. Retains the "cold air" aspect of the OEM intake, is cheap, and basically makes the most power. It's just not a restriction. If you want a fancy pipe, the Perrin intake tube is another cheap addition that doesn't require a tune as it's not changing the pre-MAF sensor flow or the housing the MAF sits in.
IMO, any sound changes you want should be done via the exhaust. Much safer this way.
cmiovino is offline   Reply With Quote
The Following 4 Users Say Thank You to cmiovino For This Useful Post:
Clipdat (05-25-2023), Pat (05-25-2023), Teseo (05-26-2023), tomm.brz (05-25-2023)
Old 05-26-2023, 12:01 AM   #11
Turdinator
Señor Member
Turdinator's Avatar
If you want sound and not worried about dollar to performanec etc, the grimspeed one works well and if you leave the top cover off its loud.
1974 TA22 Celica
2013 86 GT
Old 05-26-2023, 11:01 AM   #12
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
The Mishimoto silicone induction hose isn’t a bad mod, you get slight gains. I’ve got one on my car, the main reason I got it was to clean up the engine bay and get rid of the sound tube.
https://www.mishimoto.com/engineerin...ent-completion
Dirty Harry is offline   Reply With Quote
Old 05-26-2023, 12:42 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
I shortened the stock intake trumpet behind the front bumper. Gets a touch more 'growly'. My next try is going to be removing the resonator boxes.
Old 05-27-2023, 10:02 AM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
https://www.google.com/search?q=snor...id:GlEnNFmWpps
choosing between 2 frs's (please help) allowe Scion FR-S / Toyota 86 GT86 General Forum 56 09-26-2016 12:13 PM
Need help choosing kit DannyFRS Forced Induction 16 11-15-2013 03:49 PM
Choosing the Right Color gonzalj1 BRZ First-Gen (2012+) — General Topics 58 11-06-2013 12:46 PM
Need help choosing... ap5512 Other Vehicles & General Automotive Discussions 23 09-18-2012 07:24 PM
