#15 | |
Drives: Toyota GT86
Thank you There is room to improve but I am happy with the lap I posted ![]() As for tires Michelin pilot sport 4 the non S version
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#16 |
Drives: Toyota GT86
I got an email the other day saving my silverstone track day has been cancelled
I had a non refundable room booked at the hilton silverstone. so I did a bit of digging and found there is a track day at brand hatch that same day.So my June track day at Silverstone is now at Brands hatch indy. It will be around 2 and half hours to get there so not awful. I might try to in squeeze another mondello track day now. Speaking of here are some photos from the last track day
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | Clipdat (05-01-2023), RedReplicant (05-01-2023) |
#17 |
Drives: Toyota GT86
Just a small update I received my oil analysis from Blackstone labs and it seems fine. Will continue to run this oil and do another UOA after brands hatch.
https://bobistheoilguy.com/forums/th.../#post-6486103 I wasn't planning on doing another track day at Mondello before Brands hatch but ended up signing up for the March 31 event. I am not sure they will get enough drivers so it might get cancelled. The goal is at least a 2:09.X but I'm hopeful to get into the 2:08s if the weather is nice I also impulse bought some whiteline end links due to a 25% off sale(242euro shipped) to be used when I order coilovers after my brands hatch trip. Thinking either RCE SS2s or Shaftwork USA.
| The Following 3 Users Say Thank You to autoracer86 For This Useful Post: |
#18 |
The Dictater
Drives: '13 Red Scion FRS
Now you will need to bring 2x 17mm wrenches everywhere!
My whiteline endlinks sometimes get loose. Still a good option IMO.
Also: "Build Thread" |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | autoracer86 (05-23-2023), DarkPira7e (05-23-2023) |
#19 | |
Drives: Toyota GT86
Most likely the white lines are going back and I am ordering SPL. Trying to save money is costing me a lot in the end LOL
| The Following 2 Users Say Thank You to autoracer86 For This Useful Post: | RedReplicant (05-23-2023), Spuds (05-23-2023) |
#20 |
Drives: None
Yeah, the problem with the bigger endlinks is that they contact the bottom of the strut when turning. The SPL is much thinner but there is the slightest bit of contact to the Shaftworks in some situations.
| The Following User Says Thank You to RedReplicant For This Useful Post: | autoracer86 (05-23-2023) |
#21 |
Drives: Toyota GT86
it looks miles away in pictures but I guess in practice it's much closer. I saw you had to do a bit of grinding.
#22 |
Drives: '22 BRZ
Nordlok washers on the end link nuts on the strut side have stopped that joint loosening up on me.
Strut attached swaybars suck.
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#23 |
Drives: Toyota GT86
@RedReplicant You still had rubbing after you swapped the racer X endlinks out for the SPL endlinks ?
Oh what are you using to make the red marks ? I would like to do the same !
#24 |
Drives: Toyota GT86
Thanks for that ! Maybe you need it no matter what end links you use
#25 | |
Drives: None
![]() ![]() I definitely go overboard with the paint marking lol, but https://www.amazon.com/Acrylic-Marke.../dp/B07Z86PHP8 It comes off with brake cleaner or alcohol
#26 | |
Drives: Toyota GT86
Good to know the contact is very light. Should be fine in the end Thanks again for all the info
| The Following User Says Thank You to autoracer86 For This Useful Post: | RedReplicant (05-23-2023) |
#27 |
Drives: None
Yeah, it seems like end link stuff is much more complicated than it first appears with these cars... which goes back to DocWalt's comment, haha.
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | autoracer86 (05-23-2023), DocWalt (05-23-2023) |
#28 |
Drives: '22 BRZ
Interesting, I have no contact with my Karcepts end links (with matching swaybar) so I guess the way Karcepts positioned the swaybar arms avoids the contacts.
| The Following User Says Thank You to DocWalt For This Useful Post: | RedReplicant (05-23-2023) |
| Scratchy Noise and Peddle vibration | Sovereign | Issues | Warranty | Recalls / TSB | 7 | 07-19-2022 05:36 PM |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| JC's hot lava/burnt orange 2014 GT86 build thread | GT86NZID | Member's Car Journals | 11 | 08-25-2016 10:41 PM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
| Orange you glad you checked this thread?!? | BlaineWasHere | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 23 | 04-09-2013 05:02 PM |
