Old 05-21-2023, 03:52 AM   #169
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
You can also adjust how it hangs by getting slightly longer polyurethane hangers, which may put a little space between the tips and the cutouts.
Originally Posted by humfrz
I'm old and lazy
Old 05-24-2023, 01:55 PM   #170
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Can confirm - on my old catback setup I had the same issue with the right tip sitting significantly closer to the bumper opening compared to the left tip.
Swapping the two right hangers to these extended-style hangers which have multiple holes for some adjustment sorted it out.
JBezugs is offline   Reply With Quote
The Following 2 Users Say Thank You to JBezugs For This Useful Post:
Clipdat (05-24-2023), RToyo86 (05-24-2023)
Old 05-24-2023, 11:40 PM   #171
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Trying to keep the rear JDM hangers that are installed before ordering more hangers...
Loosened up the two slip joint clamps and rotated the elbow(shown in red) that clears the diff to see if I could move the tips around at all.
After the adjustment the right side tip went inward and maybe down a smidge; enough I readjusted both tips in/out. Going to try it like this and keep an eye on it.
The Following User Says Thank You to RToyo86 For This Useful Post:
Clipdat (05-25-2023)
Old 05-25-2023, 12:13 AM   #172
jflogerzi
jflogerzi's Avatar
Close enough for government work unless your OCD
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
RToyo86 (05-25-2023)
Old 05-19-2024, 01:34 PM   #173
RToyo86
RToyo86's Avatar
GoPro bumper mount
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
CSG Mike (05-20-2024), rb6freak (05-24-2024)
Old 12-09-2024, 01:27 PM   #174
jaits
Drives: 23' brz
Chiming in since I bought this catback used off of someone who ran it with the whole 9 yards (HKS dual resonated front pipe, tomie UEL header and overpipe) I have a 2023 with full stock exhaust other than the catback.
The problem I have is the strong smell of fumes coming out of the tips. At first I suspected of a leak in between the connections but didn't see any bubbles with the soapy water test and I dont sense the smell coming from the middle of the car, only the rear where it exits.
The catback isn't in perfect condition and I see soot within the pipe and the tips when I had it disassembled assumed it was normal use and wear. I suspect that all the catless gunk from the previous guy is soaked into the exhaust and its just blowing that nasty catless fume.
But the other way I see it is that everyone who run this CSG catback seems to go the whole 9 yards with catless headers and such, so I'm curious to know the condition of everyone's catback and if there is such issue you guys have faced. I love the sound of this exhaust but unfortunately the fume is killing me (physically and mentally lol)
jaits is offline   Reply With Quote
Old 12-09-2024, 04:12 PM   #175
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I had zero issues with fumes, I suspect yours has soot and crud inside from having no cats. I'd drive it a while and let it burn the crud off.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
jaits (12-09-2024), RToyo86 (12-09-2024)
Old 12-09-2024, 07:56 PM   #176
RToyo86
RToyo86's Avatar
Agreed probably just buildup in the system that needs to be burned off.
Old 12-09-2024, 08:09 PM   #177
callisto
Drives: 2019 Subaru BRZ
Can you take a video of it? I believe there’s a whole one videos of it on a stock gen1 and so you’d probably be the only video showing what it sounds like on gen2..
callisto is offline   Reply With Quote
Old 12-09-2024, 08:32 PM   #178
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
It's as quiet or quieter than stock.
Old 12-10-2024, 12:32 AM   #179
jaits
Drives: 23' brz
Here you go (https://youtube.com/shorts/5Ix6VjH5b...Yz4Sk3bwexVM3e)
Like DocWalt said, its quiet. It's got a good bass and hum to it. No drone, super tame, lowkey, and fly under the radar.
It's most noticeable from 2-3k rpm during take off, and also on decel which I like because it actually sounds like a sports car now. Cabin sound level is similar to the fake engine sound, but it sounds so much better and natural.
The Following User Says Thank You to jaits For This Useful Post:
DocWalt (12-10-2024)
Old 12-10-2024, 12:33 AM   #180
callisto
How is it at highway coasting, 65-70mph? It’s entirely possible it’s inaudible in that circumstance but I’ve never had anyone to ask before!
Old 12-10-2024, 01:22 AM   #181
jaits
Drives: 23' brz
Highway speed or street cruising is basically stock level of sound sitting at 2-3k rpm. The tires are equal if not louder. It is really noticeable once you do a blip for down shift, thats when it growls and pops.
At WOT/higher rpms the sound tapers off and it becomes more induction heavy
Old 12-10-2024, 01:27 AM   #182
callisto
You are my hero. Thank you for recording this!
OS Giken Grand Touring Mono Hard clutch review ofuts Forced Induction 10 10-04-2016 01:56 PM
RCE Tarmac 2 Review/Competition Log forwallblakmail Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-20-2016 07:17 PM
Essex Designed AP Racing Competition Endurance Brake Kit - Review and Install R2RO Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-26-2016 05:38 AM
DIY-TANABE MEDALION TOURING CATBACK INSTALL kinryu DIY (Do-It-Yourself) Guides 10 07-28-2014 11:05 AM
86 Tanabe Medalion Touring GA catback - Fitment pictures JDMC AUSTRALIA 26 07-09-2012 08:15 PM
