#15 |
Hey, that's encouraging! Mind taking a pic of the bore?
#16 |
Drives: Crapcan
Yeah, I will grab one and post it later.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (03-30-2023) |
#17 |
Drives: Crapcan
Not a great pic, but here is the inside of the sleeve.
The quill on my spare trans is in good shape and measured a tick over 1.292" Exedy bearing ID is 1.309", hard to measure though since it is plastic. The width of the inner bearing "race" measured .752". The inner sleeve on the BG has an ID of 1.306". The length of the sleeve that rides on the quill measured 1.387". I have a little mixed feeling about the grease groove but I don't think it will be an issue.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | DarkSunrise (03-31-2023), soundman98 (03-30-2023) |
#18 | |
ProCrastinationConsultant
| The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (03-31-2023) |
#19 |
Drives: Crapcan
That is the main thing I don't like. I may grease it lightly and drop out the transmission at the end of the year and see what it looks like.
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#20 |
Persona Non Grata
Drives: '15 BRZ (WRB)
That will be a great service to the rest of us.
Slow is smooth, and smooth is fast
#21 |
when i saw that part of the video, i started wondering about using a dry lube instead. but that still negates the grease-holder lip.
#22 |
Drives: Crapcan
Yeah. I’m kinda wondering about the dust globing up the grease and getting it flung around. There’s enough room on the back section lubricant impregnated plain bearing would fit. I’m not looking to redesign this for them though but I will message them my opinion on it after I have some time on it.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Capt Spaulding (04-01-2023), soundman98 (04-01-2023) |
#23 |
Señor Member
Silicone based greases don't grab dust in the same way petroleum ones do. Worth using if you can find an appropriate one.
1974 TA22 Celica
2013 86 GT |
| The Following 5 Users Say Thank You to Turdinator For This Useful Post: | Capt Spaulding (04-03-2023), Jdmjunkie (04-03-2023), NoHaveMSG (04-03-2023), soundman98 (04-02-2023), Wally86 (05-01-2023) |
#24 |
i can't decide if my bearing is starting to have issues, or i'm just not driving the car as much. there's times where the clutch pedal feels 'notchy'. zero noise, just a feeling in the clutch pedal that could entirely be an unfamiliarity with not using the car every day.
in any case, i ordered the full verus/bearing kit. just need to come up with the retention clips. i don't buy all the snake oil they're selling, but feel the lengthened bearing carrier should definitely help keep the bearing aligned with the clutch fingers much better than the bearing alone. and the obvious bearing shielding should definitely be an improvement as well. though despite lack of details on the 'low friction coating', i figure any coating ought to be better than no coating.
#25 |
Drives: 17 Asphalt 86
I put an order through for the full kit with versus fork. Seperately ordered an exedy OEM clutch/flywheel.
My 2017 has 75k miles with no idea how long the "revised" TOBs actually last.. |
#26 | |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
| The Following User Says Thank You to villainous_frx For This Useful Post: | RToyo86 (04-29-2023) |
#27 |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | DarkPira7e (04-29-2023), Wally86 (05-01-2023) |
#28 |
Drives: AE86, R33 GTST, X Runner
| The Following User Says Thank You to CMAutohaus For This Useful Post: | Jdmjunkie (05-07-2023) |
| Throwout bearing going bad | B-R-Z | Engine, Exhaust, Transmission | 40 | 09-08-2017 09:23 AM |
| Best quality throwout bearing? | smg1138 | Engine, Exhaust, Transmission | 19 | 07-31-2017 07:48 AM |
| Throwout bearing. | bdanisi | Issues | Warranty | Recalls / TSB | 54 | 07-17-2016 06:13 AM |
| Throwout bearing? | RavioliG | Issues | Warranty | Recalls / TSB | 3 | 10-31-2015 01:17 PM |
| act throwout bearing | blown | Engine, Exhaust, Transmission | 0 | 08-30-2015 02:17 AM |
