Old 04-16-2023, 10:24 PM   #29
Hydropkd
Drives: 2013 frs
Oh and it seems to have a stock tune. At least that is what I can tell through techstream. I would reflash it myself but I don't have the mongoose cable. Just one of the amazon mini vci's. ZA1J700C is what it says it has. I have tried to reflash with the cable I have and it says it failed to read calibration. Could it be locked by a tuner?
Hydropkd is offline   Reply With Quote
Old 04-16-2023, 10:26 PM   #30
Hydropkd
Drives: 2013 frs
Changed all fuel injectors too and made sure all the numbers matched on the port and direct both
Old 04-16-2023, 10:32 PM   #31
Hydropkd
Drives: 2013 frs
When replacing the engine we put a thin layer of antiseize between the engine and transmission. Would that cause a grounding issue? May have to end up showing or telling the dealer how to force ecu into programming mode.
Old 04-25-2023, 09:03 PM   #32
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
You will. Need a tactrix cable to flash tunes to ECU.
You cannot do it with vci cable and the pirate techstream
AussieBRZ is offline   Reply With Quote
Old 04-25-2023, 09:08 PM   #33
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
So we have still not got anywhere on this thing, found that techstream says that it needs an ecu update. Took it to dealer they said it needed it but it kept failing when they were trying to do it. Found in one of these posts that supposedly the ecu writes exhaust cam gear info on initial startup after reflash. If that's so do you guys think that my car is looking for the old cam gears?
No that's a bit of a myth
I've swapped lots of ECU between cars, reflashed no issues with cams, it's a learner setting. But very occasionally a ECU has a actual hardware problem
Does techstream show and error codes from any module in car is engine, transmission , vsc stability abs, dash cluster ?
Old 04-25-2023, 11:00 PM   #34
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
There should be a grounding strap that connects them on the top.
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-29-2021 12:52 AM
FS: Engine- 2015 BRZ FA20 56k miles FT86Logic Engine, Exhaust, Bolt-Ons 1 08-10-2018 08:07 AM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 07:39 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 04:39 AM
