Old 08-14-2022, 05:30 PM   #1
Hydropkd
Drives: 2013 frs
2015 FA20 engine in 2013 car
Have a question. I have a 2013 FRS base 6 speed with 62,000 miles. We bought it with a blown engine. Bought a 2015 engine with 30,000 miles installed it and it's stuck in limp mode 4k max. Thought maybe needed to drive to relearn everything, didn't work. Found out the wiring harnesses are different. So we changed out harness and all sensors and electronics from the 2013 engine, didn't change fuel injection parts. Only driven about 25 miles since changing that stuff. Still won't go above 4k. Any ideas?
Hydropkd is offline   Reply With Quote
Old 08-14-2022, 05:34 PM   #2
Brz-123
The ignition coil connectors are different too. Did you change them?
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
The Following User Says Thank You to Brz-123 For This Useful Post:
Hydropkd (04-16-2023)
Old 08-14-2022, 06:28 PM   #3
Hydropkd
Drives: 2013 frs
Yes changed the coil packs, just not the fuel injectors and the fuel sensors
Old 08-14-2022, 07:20 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
i believe the cam sensors are different as well. first engine iteration was a sensor wheel with four 'tits' sticking up for sensing, 15+ is 4 'divots', basically entirely opposite sensing
Old 08-14-2022, 07:31 PM   #5
Hydropkd
Drives: 2013 frs
Do you mean the cam gears?
Old 08-14-2022, 08:10 PM   #6
soundman98
soundman98's Avatar
found this thread:
https://www.ft86club.com/forums/showthread.php?t=84282
there's also this pdf for the '17 model year changes, they did some incremental changes in '15 that were detailed above. engine mods start at page 71
https://uploads.tapatalk-cdn.com/file...17MY_BRZ_1.pdf
on page 85, it talks about the cam angle sensor plates i was previously talking about. and i was incorrect. they moved from 'valleys', to 'tits' on the '17 model. but it's still a drastic difference in sensor methods
Old 08-15-2022, 08:57 AM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
found this thread:
I didn't have time to completely read through the links but, are there any obvious external differences on the engine that op can use to distinguish which engine he has.
Also the 2nd link is marked "Confidential". Did it come from Mar-A-Lago?
The Following User Says Thank You to blsfrs For This Useful Post:
Old 08-15-2022, 10:47 PM   #8
soundman98
soundman98's Avatar
it was posted in 2016 on these forums. so, yes?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
blsfrs (08-16-2022), Hydropkd (04-16-2023)
Old 08-17-2022, 05:05 AM   #9
Hydropkd
Drives: 2013 frs
No obvious differences in the two engines, the coil packs have different wiring, changed harness used 2013 coils
The Following User Says Thank You to Hydropkd For This Useful Post:
blsfrs (08-17-2022)
Old 08-17-2022, 09:27 AM   #10
https://www.ft86club.com/forums/showthread.php?t=128854
blsfrs (08-17-2022), Hydropkd (04-16-2023), soundman98 (08-17-2022)
Old 08-19-2022, 07:29 PM   #11
Hydropkd
Drives: 2013 frs
The engine says k823750. What does this tell me?
Old 08-19-2022, 07:49 PM   #12
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Ok if its got no codes and toyota\subaru cannot work it out im guessing its a tuned ecu and one of the leatures like launch flat foot shift auto blip could ve the issue
Usually with standard limp mode you get DTC code from one or more modules triggering limp
Check clutch derection switch this can trigger launcg flat foot shift mode or auto blip and srop car reving over a certian rpm
im assuming it wont rev over 4000 when its stationary and when moving
do you have a software tool like oft tactrix or ecutek to read ecu data or at leat log data ? if we can see some logs of what happens at 4000 might be a clue
AussieBRZ is offline   Reply With Quote
The Following User Says Thank You to AussieBRZ For This Useful Post:
Old 08-19-2022, 07:53 PM   #13
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Oh also with car on engine running and cruise control off, try pulling back on cruise stalk if rpm indicated on tacometer jumps to 1000 2000 3000 or 4000 without the engine rpm changing then its got an ecutek tune
Old 08-21-2022, 11:32 PM   #14
Hydropkd
Drives: 2013 frs
Oh, yea it's 4k in every gear and if you don't change gears it will die and the tach gets stuck on 4k
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-28-2021 11:52 PM
FS: Engine- 2015 BRZ FA20 56k miles FT86Logic Engine, Exhaust, Bolt-Ons 1 08-10-2018 07:07 AM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 06:39 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 03:39 AM
