Old 04-21-2023, 11:25 AM   #1
Bnagy
Drives: Gray FRS
Requirement for coilovers/camber plates with larger wheel/tire?
2013 FRS - I am putting 18x9.5 +38 wheels on the car and want to go with 265 width tires. Are coilovers and camber plates a requirement? All I am looking for is to install these wheels and lower 1". There are too many options for coilovers for me to decide. I don't track the car. It's just a daily driver. Thanks.
Bnagy is offline   Reply With Quote
Old 04-21-2023, 11:48 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You will need coilovers, otherwise your wheels/tires can hit the spring perches.
Old 04-21-2023, 11:58 AM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
17x9 with 245/40 is a much better choice for DD.
Originally Posted by humfrz
I'm old and lazy
Old 04-22-2023, 11:27 AM   #4
Bnagy
Drives: Gray FRS
What about camber plates?
Old 04-22-2023, 08:27 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Raceseng makes some nice ones.
I'm old and lazy
Old 04-22-2023, 11:08 PM   #6
DarkPira7e
DarkPira7e's Avatar
Not necessary unless you want to add negative camber. A lot of coilovers come with camber plates already if you need them (but beware, these almost all use pillow ball mounts and will clunk/creak eventually)
Absolutely necessary if you want total control over your front camber though, really.
KW coilovers and camber (without camber plates) wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 07-09-2018 08:53 PM
FS: RCE T2 Coilovers w/RCE Camber Plates and MSI Top Hats jprice130 Brakes, Suspension, Chassis 4 09-23-2016 09:36 PM
WTB: Camber plates for ST coilovers Stealthy Want-To-Buy Requests 1 04-21-2016 07:57 PM
FS BC BR Coilovers & Oni Camber Plates SLICVIC Brakes, Suspension, Chassis 0 03-01-2015 02:10 PM
FS: Coilovers W/ Camber Plates $575 Amir Ghadiri Brakes, Suspension, Chassis 8 03-11-2014 02:22 AM
