Drives: 2013 frs base
Fumoto valve and residual oil
Last weeked i had to pull my engine. I drained the oil from the Fumoto valve. After a bit, I decided since the valve might get bumped during the engine removal and transport, I took the valve out to replace it with a regular oil plug.
There was quite a bit of residual oil still in the pan. 1-2 cups? And yes, I need a new drop light. |
| The Following User Says Thank You to blsfrs For This Useful Post: | Ohio Enthusiast (04-19-2023) |
#2 |
Drives: 2016 BRZ
If I remember correctly it's because the threads of the valve itself stick up a little bit inside the pan.
Years ago on an LGT forum someone actually cut a notch in it so more drained out. |
| The Following User Says Thank You to Joon525 For This Useful Post: | blsfrs (04-19-2023) |
#3 |
I cut mine down to the depth of the female threads.
And that drop light is just fine.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | blsfrs (04-19-2023), dragoontwo (04-19-2023) |
#4 | |
Glad to see the New WRX FA24's pan has a better boss that's extended outward. Looks to have machined threads (vs formed) and there are more threads as well. WRX top left, BRZ on the right... How much of this really matters? Probably very little since at an oil change, you have almost a quart suspended in various places in the engine anyway. Just another reason to be vigilant with oil changes. . |
| The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post: | blsfrs (04-19-2023), dragoontwo (04-19-2023), Ohio Enthusiast (04-19-2023), soundman98 (04-21-2023), Wally86 (04-20-2023) |
#5 |
Drives: 2018 BRZ
Add an oil cooler and you have a whole additional quart not being drained.
| The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
#6 |
Persona Non Grata
Drives: '15 BRZ (WRB)
And the unasked question. Does it matter??
General answer. Probably not. I change mine on a warm engine primarily to ensure that the oil is well mixed. Even on an in-line vertical cylinder engine I never got all of it. On an “H” configuration? Fuggidaboutit
Slow is smooth, and smooth is fast
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#7 |
Drives: 2005 Toyota Camry
unless you're doing UOA at every interval its not super important.
more important is regular maintenance as needed. |
| The Following User Says Thank You to mav1178 For This Useful Post: | blsfrs (04-20-2023) |
#8 |
so, wait. is it regular maintenance, or as needed?
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (04-20-2023) |
#9 | |
Proud of BOXER
Drives: Subaru Boxer
Regular maintenance, as needed.
| The Following User Says Thank You to Clipdat For This Useful Post: | soundman98 (04-21-2023) |
#10 |
Mine regularly needs maintenance.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#11 | |
Proud of BOXER
Same.
| The Following User Says Thank You to Clipdat For This Useful Post: | blsfrs (04-20-2023) |
#12 | |
Be Kind
Drives: 2020 86
| The Following 2 Users Say Thank You to Wally86 For This Useful Post: | blsfrs (04-20-2023), Capt Spaulding (04-21-2023) |
#13 |
We tee in a drain valve, or if access is easy, just pull the lower line. OEM coolers tend to be more user friendly with a drain and decent access. Wish more aftermarket coolers did the same.
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | blsfrs (04-20-2023), Ultramaroon (04-20-2023) |
#14 |
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | blsfrs (04-20-2023), Capt Spaulding (04-21-2023) |
| Oil changes/Fumoto valve... | CincyJohn | BRZ Second-Gen (2022+) — General Topics | 39 | 05-30-2022 08:48 PM |
| FS: Fumoto Valve w/ Lock | byun | Engine, Exhaust, Bolt-Ons | 1 | 06-13-2016 11:03 PM |
| FS: Fumoto Valve | jvenetto | Engine, Exhaust, Bolt-Ons | 6 | 10-01-2015 07:16 AM |
| Fumoto valve in the winter? | Muskokan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 02-25-2014 12:06 PM |
| FS: Fumoto quick valve | Laika | Engine, Exhaust, Bolt-Ons | 1 | 01-08-2013 01:51 PM |
