Old 03-09-2023, 02:38 PM   #1
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Lightbulb GR86 4 gear SYNCHRONIZER ring in GT86?
I have to open the gearbox for a problem with the 4 gear.
I have read there that the 4 Gear of the GR86 is improved, looking for the references I have found that they are different, while in the rest of the gears they are the same.
gt86 4 gear SYNCHRONIZER SU003-05823
gr86 4 gear SYNCHRONIZER SU003-10754
Does anyone know if the new Synchronizer is compatible with the old GT86 gearbox?
Does anyone know what has improved?
Ruben_86_ is offline   Reply With Quote
Old 03-27-2023, 06:06 PM   #2
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I couldn't take it and bought a synchronizer to see how it was��
He carries a layer of some rough material to improve friction, he will surely do his job better, but for how long?
Old 03-27-2023, 09:19 PM   #3
RedReplicant
Drives: None
cabron fibre
Looks similar to the Synchrotech that was in my old box. Price looks good on the OEM piece, I'd imagine it'd work in the older boxes. Thank you for buying one and showing us for science.
https://sync-trans.com/products/syn-...carbon-synchro
RedReplicant is offline   Reply With Quote
Old 04-08-2023, 03:19 AM   #4
Jianlun
Drives: GR86 RC
I chanced upon this thread and wanted to share my comparison of the various gearboxes. In case anyone want to swap things around. Green highlights what changed for the new gen (marketing material say stronger gears to take the higher torque). Probably useful for you guys who FI the previous gen.
This research came about cos i wanted to be sure the synchro-tech carbon synchros fit my gr86 and the conclusion is they should cos the part numbers are the same between generations.
Jianlun is offline   Reply With Quote
Old 04-08-2023, 07:17 PM   #5
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Next week I will have the synchro of the 4 of the GT86 to be able to compare with that of the GR86
Old 04-11-2023, 05:58 PM   #6
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
Definitely something has changed in the 4 Gear, the synchro has some differences in its shape and I don't think it's a good idea to use it in an old model.
Misha and the Ring GT86. Westen86 Tracking / Autocross / HPDE / Drifting 5 12-22-2020 02:21 PM
Nitro Gear Ring & Pinion DIE1000DEATHS Engine, Exhaust, Transmission 2 06-25-2019 05:42 PM
3.9 final gear - ring and pinion PantsDants Engine, Exhaust, Bolt-Ons 5 11-08-2013 03:06 AM
GT86 key ring Ryan86 AFRICA 8 05-07-2013 12:00 PM
Toyota Announces TMG GT86 Cup for ‘Ring VLN Series vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 3 12-07-2012 03:05 PM
