Old 04-08-2023, 10:15 PM   #1
Teppka
Drives: Subaru BRZ
Lower but not make it stiffer?
I’m on stock suspension and was wondering if it’s possible to lower the car but not make it stiffer than stock suspension?
Teppka is offline   Reply With Quote
Old 04-08-2023, 10:23 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
no.
the cars already almost riding on the bump stops from the factory. any lower just means you bang off the bump stops faster, which leads to a harsher ride no matter what spring rate you pick.
Old 04-08-2023, 10:53 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
How much are you willing to spend?
Jdmjunkie is offline   Reply With Quote
Old 04-09-2023, 02:07 AM   #4
Teppka
Drives: Subaru BRZ
No amount, it was a theoretical question. Thanks.
Old 04-09-2023, 07:56 AM   #5
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's going to get stiffer, but with a quality setup it won't ruin your back.
Old 04-09-2023, 12:13 PM   #6
Jdmjunkie
Wisefab has a two inch drop knuckle setup, but it is about $3k per axle.
Old 04-14-2023, 03:25 AM   #7
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
https://www.ft86club.com/forums/showthread.php?t=89274
Old 04-14-2023, 10:01 AM   #8
alphasaur
friendly
Drives: 17' 86
RCE yellows might be what you're looking for
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 04-14-2023, 10:15 AM   #9
Ohio Enthusiast
Drives: 2018 BRZ
RCE yellows are noticeably stiffer. They do come with shorter bump stops, though.
Old 04-14-2023, 10:22 AM   #10
Racecomp Engineering
Stiffer springs are pretty much a must.
Softer/better dampers are possible.
Even with a reasonable budget, some set ups will be better over certain types of bumps (maybe even most bumps) and slightly worse over other bumps.
- Andrew
Old 04-14-2023, 10:51 AM   #11
StraightOuttaCanadaEh
Wes
honestly it's really not that bad. I remember thinking "wow this is just like OEM". Mind you it depends on the settings and it is worse over *some* bumps and it does tend to get worse as the car ages, but it's very very livable
Instagram: @gt86ws
Old 04-18-2023, 09:50 PM   #12
Teppka
Drives: Subaru BRZ
It wasn’t rhetorical question.
Old 04-18-2023, 09:58 PM   #13
Teppka
Drives: Subaru BRZ
- Andrew
Thanks. I know it’s subjective but will the ride be significantly stiffer compared to stock springs? I’m pretty happy with my factory shocks and springs, but was thinking if it’s worth thinking of lowering the car. Also these seems to be out of stock on your website and few others I checked. Is there a general shortage at the moment? As probability with everything else these days.
Old 05-03-2023, 09:02 AM   #14
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
In general, a full coilover is going to allow you to change the ride height without killing your suspension travel. Lowering springs reduce suspension travel to lower the car whereas coilovers shortent the strut body to do the same thing on some models/brands.
If you do go with some of the more expensive options, you can actually get the car to ride better than stock and even opt for soft springs. More or less, you can tailor the suspension to fit what you need it to do.
I never liked lowering spring on cars. I ran 2-3 different sets on my WRX and you hit the bump stops on hard corners. Ride was never really great on any of them either.
cmiovino is offline   Reply With Quote
Adjustable shocks getting stiffer on same setting? Lucky21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-10-2022 12:03 PM
Slightly stiffer rear sways make a difference??? SwaggFPS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-24-2016 07:48 PM
KW V3 Coilovers feel stiffer over time? mkivalex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-20-2015 08:28 AM
Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 02-20-2014 03:50 AM
ANy idea to make the seat lower? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 9 02-17-2013 02:05 PM
