Old 08-03-2022, 11:08 PM   #1
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Adjustable shocks getting stiffer on same setting?
Hi everyone my car is currently on tein endura pro shocks. It seems that every few drives the car rides stiffer than what I set the dampers to, then I readjust it and in my experience the car rides like normal again. Just wanted to know if this is an actual thing that happens with adjustable dampers or is it a placebo?
Lucky21 is offline   Reply With Quote
Old 08-04-2022, 10:56 PM   #2
strat61caster
strat61caster's Avatar
Probably in your head unless something is moving or those dampers are garbage.
ineedyourdiddly
Old 08-04-2022, 10:58 PM   #3
norcalpb
norcalpb's Avatar
I agree with this. Sometimes my car feels stiffer or softer depending on the mood I’m in.
Old 08-10-2022, 12:03 PM   #4
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Temperature will effect tire pressure; higher temps will increase tire pressure and your ride quality could suffer if they are too high.
Lincoln Logs is offline   Reply With Quote
Q: coilover damper setting. front stiffer or F/R the same ya1713 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-19-2015 12:10 AM
Bilstein B6/B8 and B14 shocks setting Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-26-2014 10:24 PM
Spring Rates Discussion: Stiffer Front or Stiffer Rear or Even/Square all around??? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 02-20-2014 03:50 AM
Non-adjustable shocks? shawnperolis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-26-2013 03:38 PM
Setting adjustable sway bar links Im_SPEED Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-01-2012 09:12 PM
