Old 04-03-2023, 02:47 PM   #1
se7en_force
Drives: BRZ 2013
Talking Looking for mechanic for clutch job due to 2013 TOB
Hello,
Hope this is correct section of the boards to post this in. My TOB went out and my research lead me to buying a new after-market clutch and flywheel, fork, and another small part. I am calling around the Sacramento area and getting labor quotes around $1400, yet also seeing labor between 3 and 9 hours for this job on the forums. Can someone recommend to me a mechanic, could even be themselves, to help me get this done at a lower rate? My initial research lead me to expect the job to be around $300-500 at roughly a 3-hr job. To be fair, I don't know if that's accurate, so open to being told that is too low or unreasonable just sharing what I found surfing the forums. Any help is appreciated.
Thanks all!
se7en_force is offline   Reply With Quote
Old 04-03-2023, 08:04 PM   #2
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
3 hours is a little tight, 4 hours reasonable. Anyone that will do it for less than $500 in labor I would worry about their quality.
2013 frs burned out clutch? or something related scionhobokenD NY / NJ / CT / PA 12 08-10-2021 09:33 AM
Mechanic for clutch and flywheel recommendations? russsak Engine, Exhaust, Transmission 4 10-23-2018 11:47 PM
Best independent mechanic to replace clutch? Barre Northern California 2 09-15-2017 02:57 PM
PS:PA Stock 2013 Clutch and flywheel 3k miles SterlingBrz Transmission and Driveline 1 01-11-2017 12:06 PM
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
