Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 03-30-2023, 01:52 PM   #29
norcalpb
norcalpb's Avatar
Originally Posted by OkieSnuffBox View Post
IIRC, and there is no guarantee I do, at least on the 2nd gens it uses the speed from the ABS Sensors + the RPM to calculate the gear.
Next time you go for a drive, when you shift, you'll notice just a slight lag before it displays the gear you're in.
On the first gen it calculates based on engine revolutions per mile. There is a table in Romraider where you can adjust it.
norcalpb is offline
Old 03-30-2023, 04:15 PM   #30
OkieSnuffBox
Drives: '23 BRZ Limited
Which means it would need to use the ABS sensors, right? Otherwise how is it calculating revolutions per mile?
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
OkieSnuffBox is offline
Old 03-30-2023, 05:31 PM   #31
norcalpb
norcalpb's Avatar
Wheel speed sensors
norcalpb is offline
Old 03-30-2023, 05:57 PM   #32
OkieSnuffBox
Wheel speed sensors
Wheel speed sensor, ABS sensor, it's the same thing.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
norcalpb (03-30-2023)
Old 03-31-2023, 08:36 AM   #33
BioRebel
Drives: Mini Cooper S
Originally Posted by vindiesel View Post
How many miles you drive a year?
It's more about how many highway miles I plan on driving. I'm used to getting 30+mpg @ 80mph highway in my old mini. It's a mild annoyance but getting 30+ with the current final drive has me capped at 75mph.
EDIT: this car doubles as my daily (though I don't drive daily) so it does go on road trips.
BioRebel is offline
Old 03-31-2023, 03:11 PM   #34
CSG Mike
CSG Mike's Avatar
Have you considered more eco friendly tires and possibly lightweight wheels?
There's many ways to find more MPG.
CSG Mike is offline
Old 03-31-2023, 03:21 PM   #35
OkieSnuffBox
Originally Posted by MyHybridBurnsGasAndTires View Post
yeah do tell us about the exact cost of making a 7 speed transmission that will fit this engine
is there an emoji on this forum for jacking off?
He probably thinks the GMA T.50 is garbage and that Gordon Murray doesn't know what he's doing because it uses a 6 speed.
Old 03-31-2023, 05:08 PM   #36
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
I don’t understand people wanting to do a mod that has no return investment or depreciating on sale of car to worry about a few mpgs less of fuel a year and a couple 100 dollars of cost of fuel consumption added for “more torque per gear acceleration” its counterintuitive. You mod for fun… gas consumption is negligible and shouldn’t be a factor in a sports car.
What’s your threshold a 1.875mpg loss? lol you get what I’m saying
The stock gearing to me is perfect for city and hwy balance. 4.3 would be fun for tight curvy roads and annoying on the highway especially with an exhaust.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline
Old 04-02-2023, 12:28 PM   #37
OkieSnuffBox
And the twisties, or track is the only place it makes sense. In a straight line it's typically slower because of the extra shifts. Figured this out on my R6 years at the drag strip and you can even shift way faster on those than a car.
Going through the traps in 5th was slower than going through the traps in 4th.
Old 04-02-2023, 05:26 PM   #38
vindiesel
vindiesel's Avatar
I have had plenty of sport bikes as well. Rode dirt bikes since I was 8 (36yrsold now) I’ve retired motorcycling. Last bike was 2012 zx10r sold 2 years ago. Felt the brz would suffice my itch for cornering.
600cc need all the gearing they can get -1f +2r sprocket to start.
Old 04-02-2023, 09:54 PM   #39
OkieSnuffBox
Yep, that's exactly the gearing change we made on it. Fun when we got to Southern Missouri and NW Arkansas, most of the time you could just leave it in 4th and go.
To keep ourselves in check on the street, we took the motto that if you had to use the brakes you were riding too fast. IE, banging gears when it's straight to nail the brakes and downshift for the corners.
Just keep it nice and smooth. But I haven't ridden in years since I wrecked at the track and ended up with post-concussion syndrome. It's terrible.
vindiesel (04-03-2023)
Old 04-03-2023, 08:37 AM   #40
vindiesel
vindiesel's Avatar
You learn to love something like riding so much sometimes you need to learn to let it go. Between skill, confidence and some probable luck eventually the best of riders will be dealt a hand they have to fold. Hopefully they come out unscathed and not permanently injured or dead. I miss it glad you are ok.
Old 04-03-2023, 01:33 PM   #41
OkieSnuffBox
Yeah. I watched one of my good friends get killed. 3 of us also went down in the wreckage, I was the only one not banged up enough to make it home
Seeing a friend dead on the road, really fucks you up.
vindiesel (04-04-2023)
Old 04-03-2023, 11:37 PM   #42
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
It's not just MPG. An engine that's spinning at 3500 when highway cruising has more vibration, noise, and wear. It deters high speed cruising. In my STi I'd gradually back off to 70 cuz it just didn't "feel" like it wanted to go 80 for hours. A 4 cylinder will never lope along at 80mph like a Corvette but something closer to 2500rpm is a lot more pleasent when power isn't needed and you're trying to comfortably cover miles. You can always downshift for uphills and passing.
But yes, I do want the lightest 17x7.5 43mm wheels, though might settle for the GR accesory wheels, and when the stock tires wear out I'm going to consider rolling resistance ratings (and weight) on replacements. I suspect low rr tires would be quieter as well.
Lelandjt is offline
The Following User Says Thank You to Lelandjt For This Useful Post:
norcalpb (04-04-2023)
17+ MT Rear Diff Assembly 4.3 FD 86TOYO2k17 Want-To-Buy Requests 2 05-10-2020 02:04 PM
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
17+ 4.3 Rear Diff ka-t_240 Want-To-Buy Requests 1 04-11-2018 09:24 AM
wtb rear diff APEXIT53 Want-To-Buy Requests 0 04-11-2016 11:15 AM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
