Old 07-27-2012, 01:18 AM   #29
notFRS
Drives: BRZ Sport-tech
Originally Posted by thermobox View Post
Yep. Got both the right and wrong ones from J-Parts. They have always been very easy to work with as far as ordering. But like my mistake, make sure that you only order the right part because they will not take returns.
More than a few people have been burned by this so far... I ran into the same mistake with them as well, BEFORE they updated their site with any information or clarification.
Make sure you know exactly what you're ordering when you put an order through them.
Looks fantastic once installed.
notFRS is offline   Reply With Quote
Old 08-03-2012, 03:59 AM   #30
notFRS
OEM+ goodness.
The Following User Says Thank You to notFRS For This Useful Post:
schtebie (08-03-2012)
Old 08-03-2012, 07:28 AM   #31
schtebie
Drives: CBS BRZ Limited
Originally Posted by notFRS View Post
OEM+ goodness.
Out of curiosity, how long did it take to install and how difficult was it?
schtebie is offline   Reply With Quote
Old 08-03-2012, 08:57 AM   #32
thermobox
Drives: 16 Impreza 5dr CWP
5 minutes. Very easy if you are "hands on". You will need to mask off between the panel and the shifter with painters tape to avoid scratching the area in front of the panel when it comes out. I pushed the tape as square against the panel as I could.
Then it is a double motion. You will grab inside the pocket of the panel, pull out-down then pull out-up. The panel comes out and you just swippy swappy the starter and harness.
thermobox is offline   Reply With Quote
The Following 2 Users Say Thank You to thermobox For This Useful Post:
schtebie (08-03-2012), tripjammer (01-15-2013)
Old 08-03-2012, 09:13 AM   #33
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Part number??
Lee358 is offline   Reply With Quote
Old 08-03-2012, 09:43 AM   #34
thermobox
ST83031ST020
The Following 4 Users Say Thank You to thermobox For This Useful Post:
Lee358 (08-03-2012), notFRS (08-05-2012), unsurety (06-03-2014), voyager2285 (02-06-2013)
Old 08-03-2012, 10:21 AM   #35
Lee358
Lee358's Avatar
ST83031ST020
And thats plug and play??
Old 08-03-2012, 11:53 AM   #36
thermobox
Yep, it's plug and play. I've got both boxes here. So I know the part numbers very well.
If you order from J-parts make sure in the drop-down that you choose the BRZ part and not the GR part.
Old 08-03-2012, 02:12 PM   #37
bullitt@uamotorsports
Drives: 1500hp 450zTT
This only works for the BRZ limited (in the US) correct?
bullitt@uamotorsports is offline   Reply With Quote
Old 08-03-2012, 02:22 PM   #38
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Yes
illmatic is offline   Reply With Quote
Old 08-03-2012, 02:22 PM   #39
Blake
Drives: Ravin Scion FR-S
Is the Scion FR-S compatible to have a push start button?? I would like to buy one but I am not sure if it's even possible???
Blake is offline   Reply With Quote
Old 08-03-2012, 02:31 PM   #40
I dont believe so since you would need the Keyless entry system which currently is only available on the limited version of the BRZ in the states. however available on the GT86 in other parts of the world.
Old 08-03-2012, 02:42 PM   #41
thermobox
That I don't know for sure and can't confirm. Due to cost savings measures I would assume this works for every push button ZN/ZC out there in the world.
But I can only confirm that said part number will fit the USDM BRZ.
Old 08-03-2012, 02:46 PM   #42
thermobox
Doubtful. To make this work on the FR-S would require you to get pretty custom with your wiring. It would almost make more sense to go with an aftermarket push-button starter due to cost.
If you were to go OE it would require:
New ignition switches/relays
Push Button Starter w/ Panel
All associated harnesses and wiring
Push button start Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 5 06-17-2012 01:45 PM
push button start standard? sparrowhawk BRZ First-Gen (2012+) — General Topics 2 03-04-2012 03:52 PM
Push button start general question maxeveland Other Vehicles & General Automotive Discussions 9 02-14-2012 10:13 AM
No push button start a good thing? Syldrin Scion FR-S / Toyota 86 GT86 General Forum 130 12-13-2011 07:06 PM
