Old 03-29-2023, 08:45 PM   #1
Kulebrero
Drives: GR86
Garmin Catalyst camera setup
Is anyone running a Catalyst camera behind the driver on a roll bar or something similar so you can see your hands on video?
I was told the camera has to go on the windshield for the system to work correctly. Is that true, and can you run a second camera in the back or facing in?
Kulebrero is offline   Reply With Quote
Old 03-30-2023, 07:44 AM   #2
M0nk3y
Yes, is it is true.
The camera needs to see the complete track as that's how the suggestions and coaching are made on your exact vehicle placement as is relates to track turn in, apex, track out...etc
No second camera option
Kyle H. - #89 STX
Old 03-30-2023, 11:41 AM   #3
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
If you want to see what you are doing, mount a Go-Pro behind you on the roll bar, then you can view your inputs as well.
I recently got a Catalyst and wanted to mount the camera back there as well...
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 04-03-2023, 10:40 PM   #4
jflogerzi
jflogerzi's Avatar
Wish I could grab one but wayyy to much money
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 04-04-2023, 08:34 AM   #5
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Have a look at the AIM stuff. The aim solo DL 2 is not too bad and will provide car data via the OBD2 port. You can add a smarty cam if you want video with overlay that you can also view along side your data in racestudio 3.
autoracer86 is offline   Reply With Quote
Old 04-06-2023, 09:18 AM   #6
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
This among other reasons is why I sold my Catalyst after one weekend's use and went back to my AIM stuff.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Garmin Catalyst on Track Strat_FRS Tracking / Autocross / HPDE / Drifting 0 07-09-2022 11:44 AM
Garmin Catalyst? Muskoka800 Tracking / Autocross / HPDE / Drifting 10 08-14-2021 02:36 PM
Garmin Catalyst Lap Timer thekevinvo Tracking / Autocross / HPDE / Drifting 3 06-16-2021 11:42 AM
REVIEW: Garmin Dash Cam™ 35 Packofcrows Electronics | Audio | NAV | Infotainment 0 07-10-2016 02:53 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
