#29 |
Drives: '22 BRZ
Reading CAN is already something RaceRom does, it won't be that hard to add a CAN Flex Fuel sensor and wire it into the CAN bus and have EcuTek read it (obviously this is dependent on them adding the code to RaceRom).
This is *not* a huge deal, for so many reasons. Either just run a Euro tune and literally nothing changes... or wait for EcuTek to add the ability to interface with a CAN FF sensor.
#30 | |
Drives: Crapcan
As tomm.brz already pointed out, easy work around. The euro roms are less buggy anyway.
#31 |
Drives: 2015 BRZ 2004 SVT Cobra
I'm FI running a mix of 93/e85 and plan on switching to full E85. Tomm.brz did my tune and switched it to the Euro version if he's not concerned, I won't be.
#32 | |
Master Collaborator
And as far as my tune is concerned, I'm pretty sure it's not a euro version. D00C are the last four digits of the CAL ID and according to @tomm.brz in his previous post, this isn't one of those. And yes, @tomm.brz, thank you very, very much to Steve99 for all of his knowledge that he has blessed us with and has allowed to remain here for us all to learn from. He has helped me out in the past as have you sir, which I am very grateful for. ![]() With that being said, until ECUTEK comes up with their own solution to the flex fuel sensor issue for USDM tunes, whether it be new code to write and/or CAN input-based, I will continue to watch and wait. I will not be updating my Pro ECU software until I know 100% what the changes are in the new version. And also @tomm.brz I don't consider myself being pessimistic, just overly cautious. If it comes to the point that I need to switch over to a euro tune, I will confer with my tuner. Thank you for your suggestion, I will definitely consider it once all the cards have been laid out on the table. @DocWalt thank you for your suggestion as well and the video link. I just hope ECUTEK can adopt the same next generation flex fuel kit and integrate it into their software suite as Cobb is doing. |
#33 |
Drives: brz 2017 hksv2
"with my tuner" so the tune you have it s not made by you, meaning probably you don't have a Racerom self tuner licence
So this update doesn't really affect you neither your current tune, it's not that after the update , the Pro Ecu software will open by itself in secret all the emission-related table and revert them to stock.. Your current tune will stay the same regardless If you will want to make mods to it, then your master tuner will have his software already updated, and if your personal software is updated is then totally irrelevant |
#34 |
Drives: frs
Damn... glad I went open source.
#35 | |
Master Collaborator
No, actually I am fully licensed with RaceRom. I have it so that I can learn the basics of tuning and what the Pro ECU software can do. But I'm definitely not learning at the risk of damaging my own engine so this current tune has been hired out. In an effort to learn, and prior to hiring out my FF/FI tune, I experimented for a little while before installing my flex fuel sensor and ethanol content analyzer and while I was still naturally aspirated, on things that would not threaten the reliability of the engine, involving a different MAP sensor and different accelerator trim settings. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | tomm.brz (03-29-2023) |
#36 |
Drives: WRB BRZ
The new EPA version will likely stop you editing any old tune functionality like flex that uses evap or rear 02,or any dtc code that's emmissions related
This may or may not be limited to USA ROMs it may be all ROM s I do not know If you don't update it will ask limit your ability to buy ecutek licences or tunes as they often want the ecutek registration code and check it for the current ecutek version. They may also stop you flashing older tunes with newer ecutek epa software don't know All a bit of an unknown |
#37 |
Steve ecutek answered by email Euro tunes won't be affected by this
| The Following User Says Thank You to tomm.brz For This Useful Post: | AussieBRZ (03-30-2023) |
#38 | |
Drives: MR2, Sliver BRZ
You seem to be freaking out so much about this. But let me propose you this hypothetical...... Can your tuner open up a stock euro ROM? Can he not transfer over all the fuel map tables and everything else needed including how you're currently set up with your flex fuel from the USDM rom the euro ROM? Then, can you not then flash that same euro ROM into your ECU? The only thing that will change is the CID and the CVN number. BUT if your in a state that checks for CID and CVN number for emissions, you would be screwed either way regardless of them doing this. I made FF kits for both gen1 and gen2 cars. The Canbus difference is not a huge deal to implement. Trust me they will find a way. There are other inputs that can be worked in. This is probably the best compromise that we could have. We are extremely lucky that our ecu can be flashed with any other markets files. Not sure about other platforms they have, but they already support canbus on alot of others.
Always looking to tinker with something..
| The Following User Says Thank You to geraldjust For This Useful Post: | DocWalt (03-31-2023) |
#39 | |
Drives: 2013 FRS GTX3076R
Could you please tell me how to bypass the ecutek compatibility check? Thanks!
#40 |
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
How do I get my hands in a euro rom?
#41 |
in your proecu software, help - update - update rom files
| Open Flash Tablet Manager Software (problem after internet update) | SloS14 | Software Tuning | 6 | 10-31-2013 03:33 PM |
| 86 Software Update | v3rgil | AFRICA | 121 | 10-04-2013 01:45 AM |
| Gopro 3 Software Update Released | Yruyur | Electronics | Audio | NAV | Infotainment | 1 | 05-13-2013 06:17 PM |
| So what ECUtek software do you need to make changes to the ECU yourself? | seven | Engine, Exhaust, Transmission | 30 | 01-04-2013 11:58 AM |
| EcuTek preparing to release PRO ECU software for BRZ | Visconti | Engine, Exhaust, Transmission | 335 | 08-13-2012 11:34 PM |
