Old 03-15-2023, 12:16 PM   #19741
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by yberther View Post
BRZ-150 filled with pop-up tent, tires, toolbox, helmet, and spares for track duty this weekend. Wet sessions nearly all day, lots of spins, glad to keep it on track all day.
That M2C in the hot pit is my buddies car lol.
norcalpb (03-16-2023)
Old 03-15-2023, 01:38 PM   #19742
JD001
JD001's Avatar
Drives: Subaru BRZ
I hadn't appreciated that Honda sold the Tye R with twin lights outside of Europe.
Old 03-15-2023, 08:36 PM   #19743
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Originally Posted by Oxyg3n View Post
Is that going from RCE Yellow Springs + OEM Struts to Tein Flex Z coils?
I'm thinking of going that exact route in the future as well, would love an update on how it compares if you get a chance!
Yes, RCE Yellow Springs/OEM Struts to Tein Flex Z. Haven't had much of an opportunity to drive it but the little I did, it really didn't feel all that much different. I made no adjustments to the Tein's other than making sure they were all set to 8 clicks from 0. When I get my summers back on and get a proper alignment, I'll get to "play" around with it.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
norcalpb (03-16-2023), Oxyg3n (03-16-2023)
Old 03-19-2023, 01:08 AM   #19744
Grady
Grady's Avatar
Finally installed new clutch today. Went with the X clutch 9.5 inch. First thing I noticed it the peddle is lighter than the ACT street clutch that has 100 ft lb less holding force. This one is a little more grabby but a lot smother than the ACT was at break in.
Old 03-28-2023, 08:12 PM   #19745
Grady
Grady's Avatar
Since this thread is slow.
I drove my car home from work today. On the 2nd tank of gas after the clutch. Once it is empty will refill with E85 and hammer on the clutch to see if it is better than the ACT that I had before.
The Following 3 Users Say Thank You to Grady For This Useful Post:
DarkPira7e (03-28-2023), new2subaru (03-29-2023), NoHaveMSG (03-28-2023)
Old 03-28-2023, 09:11 PM   #19746
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I decided to go out to the garage, reinstall my 4.3 diff, and start setting up my new coilover only to find out my RLCA's don't work with them. RacerX has a brace in their RLCA that other brands don't have and the Annex coilovers have a large lower mount that you use to set travel that don't play nice together
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
bcj (03-29-2023), Dzmitry (04-05-2023), norcalpb (03-29-2023)
Old 03-31-2023, 09:44 AM   #19747
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Got my alignment done
MrSkubi is offline   Reply With Quote
The Following 4 Users Say Thank You to MrSkubi For This Useful Post:
Busybee (04-16-2023), Dzmitry (04-05-2023), soundman98 (03-31-2023), Ultramaroon (04-01-2023)
Old 03-31-2023, 12:16 PM   #19748
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
^^^ Nice and even.
The Following User Says Thank You to gen3v8 For This Useful Post:
MrSkubi (04-01-2023)
Old 04-01-2023, 12:00 AM   #19749
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
How much negative camber in front "should" you run for DD/canyon carving? -2 degrees?
Originally Posted by humfrz
I'm old and lazy
Old 04-01-2023, 06:03 AM   #19750
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
1/2 a degree would be plenty for my sister to get a good run out of her tires. Though she would probably wear the insides more. I like -2.5 and get good wear over the life of the tire with suitable pressures. So it all depends!
Old 04-01-2023, 02:26 PM   #19751
That's what sucks about static camber. Have to decide between cornering or even tread wear. In reality, the cost of the rubber wasted is a pittance compared to overall cost of operation/ownership. We're only losing the ability to even out the wear through periodic tire rotation. IMO, for a DD, just toss in some negative and call it good.
The Following 9 Users Say Thank You to Ultramaroon For This Useful Post:
Dzmitry (04-05-2023), jcw99 (04-07-2023), MrSkubi (04-03-2023), new2subaru (04-03-2023), NoHaveMSG (04-03-2023), RToyo86 (04-08-2023), soundman98 (04-01-2023), Teseo (04-01-2023), villainous_frx (04-02-2023)
Old 04-01-2023, 05:57 PM   #19752
Teseo
Drives: frs
I'm like -1.5 or so, plenty of grip for canyon carving but without compromising tires lofe span.
The Following User Says Thank You to Teseo For This Useful Post:
Old 04-03-2023, 08:57 PM   #19753
pope
has a funny hat
Drives: 2014 BRZ Limited
Drove it for the first time since it went into winter storage in October.
Weather forecast was a bit off though. Rainy drives are still fun.
pope is offline   Reply With Quote
Old 04-08-2023, 05:57 PM   #19754
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Looked at it. Going up to 15c this week, may take it out of garage, 4 months hibernation
is enough.
CB750F is offline   Reply With Quote
