| Software Tuning Discuss all software tuning topics. |
Master Collaborator
3-28-23 DON'T UPDATE YOUR ECUTEK PRO ECU SOFTWARE!!
#2 |
Drives: brz 2017 hksv2
not a big deal, it seems to affect only USDM roms
it is possible to bypass at any time the compatibility check and flash an equivalent ( and more stable since US tune has a bunch of bugs when racerom is applied) European rom, like openflash does with their v4 OFT tunes |
#3 | |
Master Collaborator
I predict that in upcoming revisions of the Pro ECU software, (if they haven't already) ECUTEK will remove many important features preventing a large portion of it's customers from properly tuning or even obtaining calibrations for their existing tunes. It's best to hold off from updating until we hear otherwise. |
#4 |
Drives: '22 BRZ
It won't be a big deal, the Cobb software is fine after they disabled the emissions stuff. Just gotta deal with playing within the boundaries. Can't disable cold start and such anymore which is the biggest loss, I think.
Stupid diesel coal rolling turds ruining it for everyone else.
| The Following User Says Thank You to DocWalt For This Useful Post: | sftateofmind (06-25-2023) |
#5 |
Drives: 2017 BRZ w/PP
Kind of shocked this didnt happen sooner honestly. I will say there might be hope because "emission compliant" diesel tunes are getting pretty good now. Still fucking stupid considering that a handfull of cargoship make more pollution that all the modified cars combined.
| The Following User Says Thank You to Breadman For This Useful Post: | Jdmjunkie (03-28-2023) |
#6 | |
Master Collaborator
Exactly, which means in the current configuration of the programming, flex-fuel is no longer going to be an option as you must hijack either one of 3 OEM sensor inputs (CPC, MAF, or rear O2) to connect your ethanol content sensor to, in essence, removing that original OEM sensor from use, which, going forward will most likely not be possible. A few years ago, when I was just beginning to learn about ECUTek and studying wiring diagrams and the available ECU inputs, I made a statement that was pretty much disregarded by most here concerning the addition of a new sensor input, instead of the hijacking of an existing one to connect the ethanol content sensor output to. This would have avoided this whole issue had it come to fruition. One other person here was interested at the time but I don't believe it went anywhere past just being an idea. We may now have to rethink this as an alternate input possibility. |
#7 | |
You can also reswitch easily back to USDM tune then, if you need to have your car controlled So not a big deal |
#8 | |
How would that work if you were boosted? |
#9 |
Drives: JRSC BRZ SOLD
How does that effect flex-fuel tunes? They still make great power with all the factory exhaust emission devices.
#10 | |
Master Collaborator
The entire Pro ECU software suite will become almost worthless to all of the North American customers who have invested in it and I'm pretty certain that this will affect not only the home tuner here, but also every professional tuner using ECUTEK to build their tunes. My tuner resides in the US and uses Pro ECU to build his tunes and I don't want to lose his services due this issue. This is not going to be good for anyone here in NA. |
#11 |
Rust bucket enthusiast
I think it will be more dangerous to ECUTEK master tuners who likely are forced to update to keep their licensure in check. Home brew tuners using the individual licensing like me can just not update and will be fine (though excluded from future updates with the application by choosing to do so)
#12 | |
Master Collaborator
I'll answer your question with another question: How is your flex fuel ethanol content sensor connected to your ECU? |
#13 |
#14 | |
Master Collaborator
Yes, and that's why I say don't update your Pro ECU software when prompted. I have the Pro ECU suite myself and do my own flashing of purchased tunes and calibrations, but if my tuner can't write the tunes with the features that are required to operate the engine in the configuration that I need, I'm screwed. And he'll be screwed too because he lost a customer. |
| Open Flash Tablet Manager Software (problem after internet update) | SloS14 | Software Tuning | 6 | 10-31-2013 03:33 PM |
| 86 Software Update | v3rgil | AFRICA | 121 | 10-04-2013 01:45 AM |
| Gopro 3 Software Update Released | Yruyur | Electronics | Audio | NAV | Infotainment | 1 | 05-13-2013 06:17 PM |
| So what ECUtek software do you need to make changes to the ECU yourself? | seven | Engine, Exhaust, Transmission | 30 | 01-04-2013 11:58 AM |
| EcuTek preparing to release PRO ECU software for BRZ | Visconti | Engine, Exhaust, Transmission | 335 | 08-13-2012 11:34 PM |
