go_a_way1, MisterSheep
Old 03-21-2023, 05:33 AM   #24137
new2subaru
Weight Weenie
Drives: 15 FR-S
Main engine connector 12V pin was loose, I’m able to push it in and out about an eighth of an inch, another pin was bent, pushed the 12v back into place and unbent the other pin and good to go. What a pain in the ass, hope I don’t have to replace that connector.
Car finally runs, should be ready for Vegas ProSolo
What lead you to the connection? That would be a pain to figure out.
Old 03-21-2023, 03:05 PM   #24138
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Dumb luck, following the service guide we figured the maf throttle body and vvt sensors weren’t getting 12v power when they should - this was by following the codes I listed in the other post. Efi relay and the rest of the steps checked good but we were getting weird continuity errors, pins connecting when they shouldn’t (at least if my rudimentary electrician skills are worth anything). Pulled the intake off to see if there was any crushed harness which freed up the main plug so we could look into it. As I tried to probe the 12v pin on the main connector I noticed it was running away from me lol and then saw the bent pin.
Pushed the 12v in so it was seated and bent the pin back, put it back together and voila. Glad I didn’t have to cut open or buy a harness. Only lost a cup of gas or so lol. And honestly plugging into the obd2 port and paying attention, the maf had zero voltage, when the car is on you should be getting a minimum 0.127V, that’s the main tip we had a wiring issue and the solution wasn’t new sensors.
Starting an engine that had oil completely drained sounds nasty as fuck btw.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
bcj (03-22-2023), new2subaru (03-22-2023), NoHaveMSG (03-21-2023), soundman98 (03-22-2023)
Old 03-21-2023, 08:33 PM   #24139
Dumb luck my ass. That's analysis and you know it.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
bcj (03-22-2023), new2subaru (03-22-2023), NoHaveMSG (03-21-2023), soundman98 (03-22-2023), strat61caster (03-22-2023)
Old 03-21-2023, 08:50 PM   #24140
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I believe @rice_classic had a similar issue a while back that triggered some codes in his thread.
Edit: Found it.
https://www.ft86club.com/forums/show...&postcount=254
Old 03-21-2023, 09:35 PM   #24141
strat61caster
Edit: Found it.
My hallways are fine, my hotdogs were the issue. But it’s worth noting that these things aren’t really meant to be repeatedly taken apart and put back together (which is really true of all cases these days) and I’m with him, I have little desire to be a repeat Subaru owner and I’m glad I can fix stuff on my own.
Next fun car is planned to be a Porsche.
ineedyourdiddly
NoHaveMSG (03-22-2023)
Old 03-21-2023, 09:42 PM   #24142
Remember when I asked you about compression? Test also gets oil circulating at nice low speed. It's nice to crank the engine for a bit with the plugs out. Might as well check compression too.
Old 03-22-2023, 01:42 AM   #24143
strat61caster
The no start condition means plenty of pumping without spark, about as much as a compression check, didn’t really help.
ineedyourdiddly
Ultramaroon (03-22-2023)
Old 03-22-2023, 02:01 AM   #24144
Hmmm... Makes sense. No answers but interesting.
Old 03-22-2023, 11:47 AM   #24145
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Sounds like my sex life.
Originally Posted by humfrz
I'm old and lazy
The Following 4 Users Say Thank You to Clipdat For This Useful Post:
soundman98 (03-22-2023), strat61caster (03-22-2023), Teseo (03-25-2023), Ultramaroon (03-22-2023)
Old 03-22-2023, 12:28 PM   #24146
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Working on Porsche's is a bit different than Subarus. With Subarus, you're hands get dirty and you often experience frustration. With Porsche's you're on a first name basis with your mechanic, may even become part of the family.
I'm pretty sure this is in every Porsche repair manual:
"Step 1: Remove the engine"
PRO86 | WTCC | STL
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
JD001 (03-22-2023), new2subaru (03-22-2023), Teseo (03-25-2023)
Old 03-22-2023, 12:35 PM   #24147
JD001
JD001's Avatar
Drives: Subaru BRZ
I think you also have to marry the Porsche sales person before you even get a sniff of appearing on the waiting list for any of their limited run cars..
The Following User Says Thank You to JD001 For This Useful Post:
Teseo (03-25-2023)
Old 03-22-2023, 12:36 PM   #24148
strat61caster
As I learned working on spaceships - still just nuts and bolts.
The past year of fa20 problems means I’m now comfortable pulling the engine, at least with the Porsche I don’t have to buy a hoist lol. A lift in the garage may be on the wishlist though…
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
DarkPira7e (03-22-2023), Teseo (03-25-2023)
Old 03-22-2023, 12:38 PM   #24149
strat61caster
lol I’m planning to buy a 10-15 year old cayman for less then a new 86.
ineedyourdiddly
Teseo (03-25-2023)
Old 03-22-2023, 12:52 PM   #24150
It's all just nuts and bolts... and glue.
JD001 (03-25-2023), soundman98 (03-22-2023), strat61caster (03-22-2023)
