Old 03-18-2023, 04:00 PM   #1
Open Loop
2013 FR-S Whiteout / SSC
Direct Injectors stuck in head.
Hi everyone - I am pulling my injectors to replace the seals. I am at the point of removal of the first two, high pressure direct injectors on the passenger side. The port injectors are out, the intake plenum is off, the high pressure fuel line is off, the high pressure fuel rail is off, and the injector electric connections are off. The injectors have a bit of play, can spin, but do not want to come out. I am concerned about hurting them with pliers. Is there a trick to getting them out? Thank you!
Open Loop is offline   Reply With Quote
Old 03-18-2023, 04:15 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
They don't come out easily. Just pull until they do, the only thing you could hurt is the seals (or the housing if you're using tools). I wouldn't use pliers if you can avoid it. Putting them back in is scarier
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
blsfrs (05-02-2023), Open Loop (03-18-2023)
Old 03-18-2023, 10:36 PM   #3
Open Loop
Thank you. I got them out, but damaged at least one, and I am going to put new ones in.
Is the procedure to put the new ones in individually, and then install the rail on them? That seems like it makes sense.
I'm planning on putting them in the freezer to shrink them before putting them in.
Old 03-18-2023, 11:29 PM   #4
DarkPira7e
DarkPira7e's Avatar
I had mine in the freezer overnight, and the next day, attached them to the rail and used the rail to seat them evenly. Tightening the rail down very slowly and evenly (switch left to right every couple ratchet rotations) you'll eventually feel them pop in
BatStig (03-25-2023), Open Loop (03-19-2023)
Old 03-21-2023, 09:15 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
This is what I did too. I brought them out to the garage 2 at a time, Lubed them up and gently worked them in by evenly tightening the rail bolts. A couple of them made a swoosh sound as they went in, others just slowly sled in. Very satisfying.
The Following User Says Thank You to blsfrs For This Useful Post:
Open Loop (04-01-2023)
Old 04-01-2023, 02:31 PM   #6
Open Loop
OK - I finally have the new high pressure injectors.
I am considering putting them in one at a time, getting them 95-99% installed into place by hand individually, and then putting the rail on them, fastening the metal clips, and then slowly tightening them into place. Does this sound like a bad way to go?
Also, what is the best (or appropriate) lube for these?
Thanks again!!
Old 04-02-2023, 11:38 AM   #7
blsfrs
blsfrs's Avatar
Thanks again!!
Are the teflon seals preinstalled and properly "shrunk"? If not, do more research. The injectors won't, by hand, slide in past where the seal engages the hole in the head. Once out of the freezer, I quickly installed them in the rail, lubed them with Mobil 1, and worked them in with the rail bolts before they warmed up.
Old 04-02-2023, 10:18 PM   #8
Open Loop
Thanks - they are new OE injectors with seals preinstalled. I really don't want to screw them up when installing.
The Following User Says Thank You to Open Loop For This Useful Post:
blsfrs (04-03-2023)
Old 04-03-2023, 10:23 AM   #9
Tokay444
Then maybe you should do them in the method people who have done it successfully in the past prescribe.
Old 04-08-2023, 07:26 PM   #10
Open Loop
Torque specifications for Direct Injector Job
What is the best place to find the torque specifications for this job - for the direct injector fuel rail bolts, intake manifold, throttle body, port injector bolts, etc.
I'm about to seat and tighten down the new direct injectors.
Thanks in advance.
Old 04-09-2023, 08:55 AM   #11
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Go here for service manual;
gt86stuff.onrender.com
You’ll find 14 ft/# for the rail bolts and 57 in/# for the union nuts for the fuel tubes.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Open Loop (04-09-2023)
Old 04-11-2023, 12:12 AM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Well, how did the install go?
Originally Posted by humfrz
I'm old and lazy
Old 05-02-2023, 06:14 AM   #13
Open Loop
It went great. It seems like putting them on the rails first is the only way to go. I put them in the freezer first. Required a bit of a push to get them going. Car runs noticeably smoother, and have had a couple successful autocrosses and a track day on them.
The Following 5 Users Say Thank You to Open Loop For This Useful Post:
bcj (05-02-2023), blsfrs (05-02-2023), Clipdat (05-02-2023), DarkPira7e (05-02-2023), whataboutbob (05-02-2023)
Difference between direct injectors? maximumz Engine, Exhaust, Transmission 1 08-30-2022 11:41 AM
Direct Injectors stuck replacement tool? brandonblt2 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 07-28-2022 03:38 PM
Cleaning direct injectors after E85 use SPCorBUST Engine, Exhaust, Transmission 14 01-15-2022 11:36 AM
SOLD Direct injectors bhmax Engine, Exhaust, Bolt-Ons 3 12-21-2020 03:02 PM
Direct Fuel Injectors Silverspeed Engine, Exhaust, Bolt-Ons 0 10-20-2016 07:04 PM
