Old 06-30-2022, 06:13 PM   #169
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Reinstalled the old module. I am successfully back to square one. Which is good because I have an event this weekend. Pedal dance still not working, but 5sec hold works, so we'll be ok.
Again, any help or suggestions would be great.
gcranston is offline   Reply With Quote
Old 07-02-2022, 04:34 PM   #170
slockin
slockin's Avatar
Drives: '13 BRZ 6MT WRB
Do you have an ODBII reader that can pull / reset codes from the ABS module?
IIRC, when I upgraded mine ABS module there were codes already in the ABS module and resetting them did the trick. See comment 131.
slockin is offline   Reply With Quote
Old 01-03-2023, 03:52 PM   #171
amirnew
Drives: 2013 BRZ sprintex SC
Hi,
I have a sept 2012 built car, used *60 pn unit, repined the vsc connector from 17 and 32 to 8 and 9. And i have cel plus abs and steering wheel error, the fault code is speed sensor and i have no odometer now and car reva to 4k.
Can someone help? The unit ia from 2019 \2020 manual brz.
Pls.help.
amirnew is offline   Reply With Quote
Old 01-03-2023, 04:58 PM   #172
amirnew
I have the same issue on my car. Torque app scan tells me i have speed sensor issue in "historic"faults, but when clearing the fault it comes back... So not so historic...
Don't understand what os the issue. The unit is from 2019 brz but it acts like i didnt repin the connector.
The white speed sensor pin is from the vsc to the ecu?
As an input to the ecu?
Old 03-14-2023, 01:06 PM   #173
RedReplicant
Drives: None
Anyone tried a gen 2 unit on a gen 1 yet?
RedReplicant is offline   Reply With Quote
Old 03-14-2023, 01:10 PM   #174
bhmax
Drives: 13 BRZ, 17 Focus RS
Have there been supposed improvements? I haven’t really kept up with too much gen 2 stuff. Still very happy with 2017+ module on my 2013.
bhmax is offline   Reply With Quote
Old 03-14-2023, 01:16 PM   #175
RedReplicant
Drives: None
No idea, but it'd be nice if the ABS was less intrusive since it'd have been calibrated for a PS4 rather than a Prius tire.
Old 03-14-2023, 01:27 PM   #176
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Hate to break it to you, but the second gen still comes with "Prius tires" and the same unit is used on the premium and limited.
Old 03-14-2023, 01:54 PM   #177
RedReplicant
Drives: None
That sucks. Same software calibration id?
Old 03-14-2023, 02:05 PM   #178
dragoontwo
dragoontwo's Avatar
Probably. I'm not sure if the ABS CAL ID is listed on the outside, or pulled by interfacing to the car. The Subaru parts diagram lists the same ABS unit for both trims.
Old 03-14-2023, 02:09 PM   #179
RedReplicant
Drives: None
Alright, I have a working techstream setup so I'll pull calibration ids from both trims at the next track event in two weeks.
I was just hoping we'd be in a similar situation to MK60/MK60E1/MK60E5/MK100 where you can code the unit to different parameters that intervene less.
Old 03-14-2023, 02:51 PM   #180
Ohio Enthusiast
Drives: 2018 BRZ
When I test drove a '22 BRZ I found the stability and traction controls to be less intrusive when fully on - 1st to 2nd high RPM upshift chirped the wheels (would bog down my '18) and it allowed a nice amount of rear slip coming out of a stop sign and turning left (would feel brake intervention in my '18). I only drove with stability and traction fully on, so not sure if there is a different tuning in Track Mode.
But if your goal is just to have a "fully off" mode the 17+ is good enough, AFAIU.
Old 03-14-2023, 04:41 PM   #181
gpvecchi
gpvecchi's Avatar
I have the STi unit, and it's calibrated different than my previous 2019 version. ABS is less intrusive, ESP the same. My opinion it's calibrated for 18 inches rims, so I think the GR86 has a similar behaviour.
I'm tempted to try the JDM G type (same as the JDM 86 GR). this looks more track oriented than the others.
Old 03-14-2023, 05:39 PM   #182
RedReplicant
Drives: None
Do you know the CAL ID for it? I wonder if this is something we can change. I'm going to poke around in my car later with Techstream.
I am assuming Brembo calibration is less intrusive too.
Review of "Track Mode" on the MY17+ cars trippinbillies40 Tracking / Autocross / HPDE / Drifting 85 02-22-2021 09:27 PM
FS: Nameless muffled track pipe 2013-2016 Dave-ROR Engine, Exhaust, Bolt-Ons 4 05-20-2020 11:27 PM
Track mode vs. VSC sport alex87f Scion FR-S / Toyota 86 GT86 General Forum 9 10-30-2018 10:47 PM
2017 Track mode on older model Bobster Engine, Exhaust, Transmission 17 12-03-2017 10:34 PM
