BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
11-12-2021, 06:24 PM | #15 |
Drives: Until recently, a 2020 Hakone 86
From torquenews.com:
"Subaru uses a form of the Subaru Global Platform but says the sports coupe couldn't share the same frame as a mass-produced car. The BRZ achieves optimum weight distribution of 53:47 with two people on board. They replaced the old hood and roof to make this happen." So the key to proper weight distribution is to always have a passenger with you? |
The Following User Says Thank You to 86-75309 For This Useful Post: | Jucostud (11-12-2021) |
11-12-2021, 06:30 PM | #16 |
Drives: 2022 GR86
11-12-2021, 09:35 PM | #17 |
Drives: 2015 FRS for daily and track use
Will be getting ours this weekend. Can't wait to get it on the dyno back to back with our 2015 FRS (which is modded).
11-13-2021, 01:57 AM | #18 |
Drives: Black BRZ
I honestly cannot wait till someone starts a weight loss thread with these...
...nothing too crazy like Anthony's weight loss build with his FR-S, but seeing these down to 2500lbs would be SO COOL! |
The Following User Says Thank You to WC-BRZ For This Useful Post: | Simmons (11-13-2021) |
11-13-2021, 07:00 AM | #19 | |
Drives: 2022 WRB BRZ limited
11-13-2021, 07:40 AM | #20 |
Drives: 2022 BRZ
I am wondering where the extra weight is on these over the 1st gen. I had my 13 Brz down to 2,555lbs in STX trim.
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
11-13-2021, 08:12 AM | #21 | |
Drives: '23 BRZ
53:47 is *far* from "optimum" for an FR sports/sporty car, and they couldn't even achieve that. Weight distribution is the same 55F/45R as the last-gen. Not great... |
11-13-2021, 08:13 AM | #22 | |
Drives: 2022 BRZ Limited SBP
11-13-2021, 08:24 AM | #23 |
Drives: '23 BRZ
Yes, weight with me in the driver's seat. If the rear wheels were where they should be, right behind the front seats, driver weight would be mostly on the rear wheels. As it is, with rear wheels shoved way aft, driver weight is ~45F/55R...
The Following User Says Thank You to ZDan For This Useful Post: | Rcode (11-13-2021) |
11-13-2021, 09:27 AM | #24 | |
TRACKBREAD
This car is almost exactly the same as the old one. Overall weight changed by less than 1.5%. Even going from 55/45 to 53/47 is probably with both seats all the way back, no washer fluid, and all the shit from the glove compartment in the trunk. |
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | MyHybridBurnsGasAndTires (11-13-2021) |
11-14-2021, 09:19 AM | #25 | |
Drives: '15 BRZ RA
Aluminum front fender: -3.0kg Aluminum front housing: -3.0 kg Aluminum roof panel: -2.0 kg Hollowing of front stabilizer: -0.5kg Weight reduction of muffler: -1.6 kg Weight reduction of front seats: -2.6 kg Weight reduction of propeller shaft: -1.1 kg Front to rear weight distribution is almost the same. Not that much of a difference. There were also voices going into a turbo setup, but then front weight would be much more and cornering performance worse. Price would be higher too. |
11-14-2021, 01:57 PM | #26 |
Custom User Title
Seems to be some conflicting information on if headers swap or not. My understanding was it's a different size so headers aren't swappable but there are people in here saying theirs swapped? What's the consensus?
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
The Following User Says Thank You to Locust For This Useful Post: | cactus (11-28-2021) |
11-21-2021, 05:16 PM | #27 |
Drives: 2019 Tundra TRD SPORT
Interesting OP...thanks for posting.
The Following User Says Thank You to GoodToBeKing For This Useful Post: | Jucostud (11-22-2021) |
03-07-2023, 04:34 PM | #28 |
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
Adding a donut spare tire brings the weight distribution closer to 50/50.
Similar Threads | ||||
Corner Scales? | Campo | Arizona | 1 | 02-14-2022 04:58 AM |
Vorshlag BRZ/FR-S/86 Camber Plates for KW v3 | AWE46M3 | Brakes, Suspension, Chassis | 0 | 06-24-2020 08:58 AM |
OFT - Example alternate maps for AT, 98RON, E85, MAF Scales | Wayno | Software Tuning | 562 | 06-24-2017 04:36 AM |
Vorshlag LSX kit | cf6mech | Engine Swaps | 749 | 12-06-2016 04:21 PM |
any one sell vorshlag?! | FISHBURGLAR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-20-2015 01:49 PM |
