Old 03-06-2023, 09:49 PM   #1
londonbell
Drives: GTS 86
Need some help for upgrade steering wheel from 2013 to 2017
I am interested in upgrading both my instrument cluster and steering wheel from the current 2013 models to the OEM 2017 models. I have found some options on the internet, but I have a question regarding the 2017 steering wheel they are selling. It does not come with an airbag and airbag cover. Can I swap my current 2013 airbag into the 2017 steering wheel with the OEM 2017 airbag cover?
Additionally, after installing the 2017 steering wheel (which has remote control), will I be able to use the multi-function LCD cluster without buy retrofit kit?
londonbell is offline   Reply With Quote
Old 03-07-2023, 12:32 AM   #2
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
On the airbag canisters the conectors look the same but the labels are different so they may be compatible. Hopefully someone more knowelgable than me can weigh in on this. I don't think that you can buy just the cover from the dealer so it may be easier just to buy the whole airbag assembly.
Toyota: https://parts.toyota.com/p/Toyota__8...U00307066.html
Used: https://www.redlineautoparts.com/sub...bag-srs-fb030/
Name:  Screenshot from 2023-03-06 19-10-58.png
Stephen02 is offline   Reply With Quote
Old 03-07-2023, 12:49 AM   #3
londonbell
Drives: GTS 86
Attachment 218962
Attachment 218963
Thanks for the information, mate! I found some airbag covers online for the 2017-2019 BRZ/86, which means I can give it a try.
Old 03-07-2023, 12:55 AM   #4
Stephen02
Stephen02's Avatar
No problem! Be careful.
What to buy? Upgrade steering wheel without airbag/ traction control dash lights? Falkon240 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-03-2023 03:40 PM
FS: 2017+ Steering wheel - 2017+ Steering wheels covers trueno86power Interior Parts (Incl. Lighting) 5 06-26-2022 06:11 PM
Aliexpress $40 steering wheel upgrade SuperTom Cosmetic Modification (Interior/Exterior/Lighting) 7 05-17-2022 04:20 PM
Swapping 2013-16 steering wheel into 2017+ BRZ/86 224brz Cosmetic Modification (Interior/Exterior/Lighting) 2 05-16-2020 02:01 PM
Swapping 2013-16 steering wheel into 2017+ BRZ/86 224brz Electronics | Audio | NAV | Infotainment 2 05-15-2020 09:29 AM
