Old 02-08-2023, 05:15 PM   #1
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
What to buy? Upgrade steering wheel without airbag/ traction control dash lights?
I have replaced almost all the OEM interior pieces the body touches from my 2013 FRS, including seats, steering wheel, shift knob, etc.
These items came with airbags/safety resistors and I believe they're not working.
I have a weight sensor resistor for the harness that goes to the driver's seat.
I'm using a Worksbell hub and the Gerald Just Projects Cruise control and horn hub.
I have ABS lights and airbag lights on.
Who successfully turned off the dash lights with resistors and links to share/purchase?
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 02-08-2023, 05:31 PM   #2
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Unplug the airbag module completely . It's behind the little cubby underneath the HVAC. Pop that thing out, and unplug the harness that's RIGHT there.
ABS light is probably unrelated to all of that though.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 02-08-2023, 06:07 PM   #3
pope
has a funny hat
Drives: 2014 BRZ Limited
If you removed the clockspring or the altered its alignment, the abs and traction systems will have errors because it can’t correctly calculate the steering angle.
If this is a street car, don’t be a muppet, restore the safety equipment.
If it’s a dedicated track car, put some black tape over the warning lights.
pope is offline   Reply With Quote
Old 02-08-2023, 06:12 PM   #4
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Originally Posted by pope View Post
If you removed the clockspring or altered its alignment, the abs and traction systems will have errors because they can’t correctly calculate the steering angle.
The clock spring hasn't been removed, I put some resistors in there but they're most likely the wrong resistance.
I can't get the cruise control to function with the ABS lights on.
I'm looking for a resistor that can replicate the resistance of the clock spring then!
Mostly track car. I'll take it around the block to get coffee every once in a while. I have a daily.
IG
2013 Scion FR-S
Old 02-08-2023, 08:46 PM   #5
pope
has a funny hat
You can’t just replicate the resistance of the clockspring, it has an angle sensor built in and the center point has to be calibrated in the computer before things like power steering, abs, traction control, cruise, etc. will work.
Old 02-10-2023, 12:27 PM   #6
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
I see! Sounds like I need to figure out how to recalibrate the clockspring/ steering angle sensors.
IG
2013 Scion FR-S
Old 02-10-2023, 12:54 PM   #7
RedReplicant
Drives: None
https://www.ft86club.com/forums/showthread.php?t=73034
RedReplicant is offline   Reply With Quote
Old 02-12-2023, 05:18 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hope you don't get pulled over and the cops a ****.
Old 04-03-2023, 02:40 PM   #9
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
Not a problem for me where I live so far.
I was able to realign the clock spring and get the abs lights to go away, but now the horn and cruise control don't work.
I think I damaged the clock spring so I'll be replacing it.
IG
2013 Scion FR-S
ABS and Traction Control lights on SOS wdmo Issues | Warranty | Recalls / TSB 7 02-17-2021 12:33 PM
Steering wheel crooked and ABS and Traction Lights On Brzxton Issues | Warranty | Recalls / TSB 12 03-22-2018 08:29 PM
WTB. Subaru BRZ steering wheel airbag and dash with bag Tosergeyr Want-To-Buy Requests 1 10-17-2015 01:46 AM
WTB Stock Intake OEM! Steering Wheel Airbag! Brz lights! amber markers sokol Want-To-Buy Requests 4 04-09-2015 02:55 AM
