Old 03-06-2023, 01:33 AM   #6511
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
We need a third bot to start a bidding war.
Lol, and none of them will have any idea what the top hats actually do.
Also: "Build Thread"
The Following 3 Users Say Thank You to Spuds For This Useful Post:
NoHaveMSG (03-06-2023), soundman98 (03-06-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 07:28 AM   #6512
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Don't they make you a cultured, sophisticated man-about-town?
The Following 7 Users Say Thank You to Sapphireho For This Useful Post:
86-75309 (03-06-2023), Capt Spaulding (03-06-2023), NoHaveMSG (03-06-2023), soundman98 (03-06-2023), Spuds (03-06-2023), Tcoat (03-06-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 07:45 AM   #6513
Yep and and long as you have one and a top coat you won't need to worry 'cuz your wallet's fat.
NoHaveMSG (03-06-2023), Sapphireho (03-06-2023), soundman98 (03-06-2023), Spuds (03-06-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 12:32 PM   #6514
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you need a hand with install let me know. I have toe plates and a camber gauge.
Old 03-06-2023, 12:54 PM   #6515
I wondered how bad my toe would be after installing. Would I shred my tires driving down to you?
Old 03-06-2023, 01:35 PM   #6516
Spuds
The Dictater
Spuds's Avatar
I probably should have gotten some alignment tools last month now that you mention it...
The Following User Says Thank You to Spuds For This Useful Post:
Old 03-06-2023, 02:17 PM   #6517
I've always had an irrational fear of alignment. I still pay for that service.
I'm sure Garth doesn't remember me but he's been my go-to for years.
Old 03-06-2023, 02:26 PM   #6518
cjd
cjd's Avatar
Drives: 2017 BRZ
Toe plates still depend on the tires being a good stable measure... make sure they're the same pressure and no bulges and...
Front toe is easy. Takes me 2hrs to do the back alignment, takes me 15 minutes to do to and camber up front. I do a string box.
The Following 2 Users Say Thank You to cjd For This Useful Post:
NoHaveMSG (03-06-2023), Ultramaroon (03-06-2023)
Old 03-06-2023, 02:33 PM   #6519
Spuds
The Dictater
Spuds's Avatar
I don't have a guy and nobody seems to know one around here unfortunately. Maybe I need to make more friends lol
Old 03-06-2023, 02:59 PM   #6520
It's a struggle! I'm as anxious as an expectant father whenever my stuff is on someone else's lift.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
Clipdat (03-06-2023), soundman98 (03-06-2023), spike021 (03-06-2023), Spuds (03-06-2023)
Old 03-06-2023, 03:25 PM   #6521
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Front camber doesn't effect toe that much. Should be okay, I'd do a quick drive around the block to verify. The rear is a PITA as @cjd mentioned since ride height, toe, and camber all effect each other to varying degrees. The hardest part about the front is making sure you keep the steering wheel straight.
Old 03-07-2023, 11:09 AM   #6522
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
@Spuds I was reading your thread on AMSOIL Trans & Diff and was wondering if you evr ran into any issues during the winter with shifting and what not. Im getting ready to do some maintenance.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Spuds (03-07-2023)
Old 03-07-2023, 12:07 PM   #6523
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Honestly, building a string box is probably better like @cjd shows in his picture. Toe plates are a bit affected by tire bulge with the car sitting on the ground. With a string box you can measure to the wheel. Camber gauge is a must if you plan on messing with your settings a bunch. I usually set mine at the start of the year and check it periodically or if I have an off or a big curb strike.
From my experience, for the trans, Redline MT-90 is the way to go. I know Ultra runs the same. Motul is shit in colder climates, I know a lot of people recommend it but I did not like it at all.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Spuds (03-07-2023), Ultramaroon (03-07-2023)
Old 03-07-2023, 12:35 PM   #6524
spcmafia
spcmafia's Avatar
I replaced my fluids when I first got the car, with 13K miles. Maybe I drove it for around 1k before I started replacing stuff (fluids, mounts). I went with MOTUL and I gotta say that while it did improve the shifting in some areas, cold months are a pain. A weighted shift knob helped a little but still. I want to go a different route and Im open to try either AMSOIL or Redline. AMSOIL would cost around $115 and RL around $100, so I wouldn't mind either or.
The other thing is that AMSOIL comes with the Easy packs that would make the fill easier, whereas R.L I would have to use some sort of pump, judging by the pictures. Not a big deal overall.
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 12:00 PM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-27-2017 12:33 AM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 08:35 PM
