Old 02-27-2023, 03:54 PM   #29
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by Dirty Harry View Post
^100% agree with this. I have after market catted headers (HKS GT-Spec), with a custom dyno tune and it is the low down torque where you notice it most. Top end is a little better, but you can become a little more “shift lazy” cruising around town as you have the extra torque down low.
As for going catless headers, I wanted to stay legal.
OP, I wouldn’t go from aftermarket catted to aftermarket catless as the gains would be negligible and you definitely won’t be legal then. Not sure about how it affects the snap, crackle and popping. If you really wanted that, you could probably get it added via a tune.
The gains are small, but do exist thanks to relieving the extra bit of restriction from having a cat to going cat-less. This has been posted repeatedly from independent sources and tuners.
My look at the whole thing is, if you're getting an aftermarket header with a high-flow cat, you're already illegal because you're tinkering with emissions related parts. So whether you choose to go with a cat-less or high-flow cat header becomes a preference thing. I went with cat-less because from doing enough reading over the years from peoples opinions and thoughts on this, I came to the consensus that there isn't much of a smell if any, and that there was slightly more gains to be had. Since I was sticking to NA, I made my choice. I have no plans to ever touch my front pipe, nor ever go to a high-flow cat in that department. The smell, alone, would turn me down.
Dzmitry is offline   Reply With Quote
Old 02-27-2023, 04:00 PM   #30
Dzmitry
Dzmitry's Avatar
Originally Posted by norcalpb View Post
I just don’t see how if the secondary cat does the majority of the work, why it wouldn’t be called the primary cat? Also why would there be 0 sensors on the secondary cat? Seems like you’d want a measurement post secondary cat if it was what really cleaned things up, instead of just post primary cat.
I’d be curious to see where you read this stuff as I could easily be wrong too. Just want to learn more about this stuff.
I don't think the "primary" or "secondary" names have anything to do with whether one does more work than the other. Purely named for purpose of understanding their location in respect to the whole exhaust. At least that was my guess. Primary comes first, secondary comes second. I do agree with you on the sensor part and don't have a good answer for that. Tried looking the other day for info to backup my statement but had little luck finding anything at all. I'll post if I do.
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
Capt Spaulding (02-28-2023), norcalpb (02-27-2023)
Old 02-27-2023, 05:40 PM   #31
norcalpb
norcalpb's Avatar
The more research I do the more it seems you are right and I am wrong. It’s just so surprising that the smaller cat is the one people remove to make the most power. My 2001 Camry has the same setup (header cat + downpipe cat) and it functions in the way you described. Safe to assume the brz must function the same?
The Following User Says Thank You to norcalpb For This Useful Post:
Old 02-28-2023, 08:44 AM   #32
Dzmitry
Dzmitry's Avatar
The more research I do the more it seems you are right and I am wrong. It’s just so surprising that the smaller cat is the one people remove to make the most power. My 2001 Camry has the same setup (header cat + downpipe cat) and it functions in the way you described. Safe to assume the BRZ must function the same?
Still unsure haha. I did a bit of reading last night myself and could not find a reasonable verdict. Everyone has mixed thoughts on this. My thought on the primary cat removed making the most power is that it's slowing the initial flow down of exhaust gases unlike the secondary which is way down the line. But I honestly don't know much about any of that other than the fact that the flow of exhaust gases is complicated - hence why we can't just throw on a bigger exhaust or remove a cat and get instant gains necessarily.
In any case, the reason we got into this topic was because of exhaust smell. And I was saying that I don't get any smell once warmed up. I was actually thinking I'll experiment for fun when I get home one day. I'll idle the car for a bit, get out, and see if I smell anything and how bad it is. Because the truth is, I hate exhaust smell and I hate to put others through that as well. That is why I was very careful about choosing my exhaust and took a long time to decide. I was looking for best gains through the power band, little to no smell, OEM+ like sound quality and quietness. I've never had an issue passing emissions testing with my setup either for the past 3 years. I live in southeast PA, so YMMV.
The Following User Says Thank You to Dzmitry For This Useful Post:
norcalpb (02-28-2023)
Old 02-28-2023, 12:36 PM   #33
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Get a friend or family member to drive your car while you drive behind it in a different car with your window down. Only way to really experience/verify if it stinks or not.
Originally Posted by humfrz
I'm old and lazy
Old 02-28-2023, 03:55 PM   #34
Dzmitry
Dzmitry's Avatar
Certainly could, but performing the simple test I described would give me most of the story. If it has little to no smell at all, that gives me comfort and anyone driving behind me should be fine as well. Granted when I'm giving it full throttle, there's probably some smell, but the reality of it is, the stock car smells at full throttle at the tailpipes as well.
Old 02-28-2023, 04:36 PM   #35
Clipdat
Proud of BOXER
Clipdat's Avatar
I never said anything about full throttle pulls, but rather I meant city cruising (25-45) speeds.
Politely disagree that attempting to check for smell at idle will give you "most of the story."
I'm old and lazy
Old 02-28-2023, 08:17 PM   #36
Lantanafrs2
Drives: 2013 frs red
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Dzmitry (03-13-2023)
Old 03-04-2023, 07:53 PM   #37
Ernest72
Originally Posted by x808drifter View Post
It's also illegal as hell but YMMV.
I think any exhaust mod is where I live. Luckily no one is checking.
Smelled many WRX/STI car that are catless .
I don’t think it’s worth it, you need at least one cat.
Old 03-08-2023, 10:42 AM   #38
tomm.brz
Drives: brz 2017 hksv2
even if it s smaller, the primary cat is a lot closer to the exhaust valves and that surely affect performance more.. it s the first big obstacle the gases encounter so it s quite big of a restriction
the secondary o2 sensor is placed after just 1 cat because it also aids in correcting the afr via fuel trims during cruising, and the first cat is already more than enough for the o2 sensor to measure different from the first, so that the ECU thinks the cat is working
Also placing the o2 sensor after the second cat would bring it much further from the exhaust valve and also close to ambient air which then makes it useless to perform afr adjustment
the 2 sensors in oem tune try their best to keep afr at precisely around 14.7 during cruising because that s the afr that produces less pollution when coupled with catalyzers
When i tune this car, i disable completely the secondary o2 to the point that you can rip it off and the ECU doesnt care, and offset the primary lambda to get a real cruising afr of 15.5 or leaner, a thing impossible to obtain when on oem tune
The Following 6 Users Say Thank You to tomm.brz For This Useful Post:
Clipdat (03-09-2023), Compelica (03-09-2023), Dzmitry (03-13-2023), NoHaveMSG (03-08-2023), norcalpb (03-08-2023), Teseo (03-09-2023)
(Invidia N2 + Catless UEL) vs (Tanabe Concept G + Catless UEL) which has less drone? YSoAggressive Engine, Exhaust, Transmission 6 06-27-2021 02:27 AM
Catless Emissions? Howaitoguru Engine, Exhaust, Transmission 10 07-09-2019 08:16 PM
What exhaust to pair with my Catless UEL & Dual-Resonated FP (Catless)? kev0 Engine, Exhaust, Transmission 7 05-09-2019 09:29 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 08:13 PM
Catless Vs HFC? Koolkiid Engine, Exhaust, Transmission 14 05-28-2013 09:03 AM
