Old 02-23-2023, 06:07 PM   #267
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
lol. Good answer.
Originally Posted by humfrz
I'm old and lazy
Old 02-23-2023, 10:53 PM   #268
jflogerzi
jflogerzi's Avatar
So much win in this thread.
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 02-25-2023, 11:42 AM   #269
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Where is the dyno?
Old 02-25-2023, 12:01 PM   #270
ML
ML's Avatar
Drives: 13 White MT FR-S
Where is the dyno?
I’m at an endurance race so I guess he didn’t get to it yesterday. Hopefully Monday!
Old 02-27-2023, 11:28 AM   #271
ML
ML's Avatar
Update: Oil pressure is too low at idle indicating an issue, so we are forgoing the dyno and pulling the oil pan to take a look at the oil pump and double check a few things.
Old 02-27-2023, 01:36 PM   #272
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Oh nooo Was really looking forward to seeing the results. Hopefully nothing major
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
Kelse92 is offline   Reply With Quote
Old 02-27-2023, 01:49 PM   #273
ML
ML's Avatar
race cars are stupid
Old 02-28-2023, 01:37 PM   #274
ML
ML's Avatar
so I got it back from the tuner after he told me he didn't feel comfortable with it. A little more clarification; the main bearning clearance is stock and the rod bearing is half a thousanth larger. The oil pressure is 24 or so cold but once to operating temp it is hitting 8psi. but at 5k rpm its around 60 psi, so am I missing about 20 psi everywhere? We are going to pull the oil pan tonight and take a look at the pump and a few other things. (huge pain cause I'm going to have to drop the subframe)
Old 02-28-2023, 01:42 PM   #275
captain awesome
Wears Pants
Drives: 14 FRS K24 swap - SOLD
I'm curious how much of a pain the subframe drop will be for you. I still need to drill my oil dipstick hole and am thinking of the easiest way to fix that without pulling everything.
With that said, hope it's nothing difficult or expensive to sort out for you.
captain awesome is offline   Reply With Quote
Old 02-28-2023, 01:46 PM   #276
ML
ML's Avatar
I emailed kpower and they said even they had not done it before! but we have a strut bar engine holder thing to keep the engine in place on the lift, but just a couple bolts, leave the steering rack in place and maybe the control arms too is the plan
Old 02-28-2023, 03:35 PM   #277
RedReplicant
Drives: None
Paging @endless_pain
RedReplicant is offline   Reply With Quote
Old 03-01-2023, 12:33 AM   #278
gnarjunkie
Drives: '23 GR86, '17 BRZ
YUP.
Heartbreakers, every one of them.
60psi at 5k rpm seems ok though? I've always heard 10psi per 1k rpm as a good benchmark.
gnarjunkie is offline   Reply With Quote
Old 03-01-2023, 07:02 AM   #279
ML
ML's Avatar
So the tech that assembled the motor didnt put the oil jet plug back in. This is what I suspected, and easy enough to fix after putting it on the lift and dropping the sun frame. Only took 3 hours total. Now I have 85 psi at idle cold haha!
Old 03-01-2023, 11:18 AM   #280
RedReplicant
Drives: None
What a relief, I'm glad that worked out for you
Whiteout FRS Eric_86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 08-28-2012 11:27 AM
MT Whiteout available now... JohnATL Southeast 8 08-09-2012 01:12 AM
Another WHITEOUT in the bay.. :) tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 31 08-06-2012 02:13 AM
My new Whiteout FR-S! Flawless22 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 07-05-2012 02:46 AM
My whiteout fr-s F3dzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 07-04-2012 07:25 AM
